Question about Grohe 27.069.EN0 Relexa Ultra Shower Head 5 with Integrated Shower Arm - In
How do i disassemble this shower head to clean out the mineral deposit?
    Scholar:
  • 67 Answers
Most often the shower head will be threaded together. Use 2 strap wrenches to take it apart. The strap wrenches will not damage the finish. Do not force it if the fixture does not come apart easily. Soak the head in vinegar overnight to loosen the mineral deposits and make it easier to work with. Good Luck
Posted on Jul 17, 2010
Triton aspirante shower 9.5kw why is there not much water pressure?
If the mains water pressure is good supplying the shower unit the restriction must be within the unit or the hose and shower head. Try removing the shower head and if no better the unit should be investigated.
Instantaneous shower units are designed for connection to the mains water supply. They can be connected to a header tank supply but a booster pump will probably be needed unless the header tank is at the top of a very tall house.
Nov 21, 2017 | Home
Any idea how to open the grey part where the water comes out of this rohl 1151/8pn handheld shower?
Joe, Soak that head in a plastic bag or container of vinegar and it will remove most if not all the deposits, just give it a little scrub with old tooth brush a few times put back in vinegar for approximately 4 hours or leave overnight. This may also allow easier disassemble.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Top 3 Tips For Cleaning Your Shower Head
How to Clean the Showerhead with Vinegar
Tie Bag of Vinegar Around Your Shower Head to Clean It with No Effort
How to Clean Your Shower Head Easy Bathroom Cleaning Ideas Clean My Space
May 26, 2016 | Rohl Home
How do i disassemble and clean delta a112.18.1 shower head
Over a period of time the minerals in our water can build up when run thru small openings, CLR (calcium, Lime, Rust) remover and cleaner will remove these deposits, mix according to label in a bucket, remove shower head and place in bucket overnight. remove rinse and reassemble with Teflon tape thread sealer.
Feb 28, 2015 | Delta Home
Shower keeps tripping out ? Only just started doing it
Calcium deposits from hard water are collecting inside the shower head. The holes are narrowing and/or clogging.
Unscrew the shower head and clean with a Calcium removing agent. Or get a new one for the price of the chemistry needed to clean the head.
Jan 05, 2015 | Home
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
The pull valve that directs the water from faucet to shower head is stuck. water leaks from shower head and can't turn it off with faucet controls. when main water line is turned off, the valve moves...
it is full of lime and scale from mineral deposits.
either chip it away to clean or remove and replace the spout with a new one which is the easiest thing to do instead
Aug 20, 2011 | Jacuzzi Home
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
Low water pressure from hand held shower wand .New home with possible mineral deposits
Sorry to read about your problem, I hope this helps you out.
Yes can disconnect your hose, at the shower head, their is a screen..check for deposits,
in addition you can soak the head in lime away or white vinegar.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Home
I have an older Delta single handle shower scald guard. Water pressure from the cold side is fine. When I turn it to hot it slows to a trickle. After a minute or so it picks up slightly but it is then hard...
It sounds like it has mineral deposits in the hot water side. Try taking the internal valve parts completely out of the fixture and examine them. If there is any scaly (light grey) deposits, that would be the problem.
The solution is to soak all the parts in vinegar, which will dissolve the mineral deposits. It takes awhile to dissolve what has taken long to build up, so heat the vinegar, or put it all on a warm, not hot, surface to keep it more active.
I had this problem, and after cleaning it a couple of times with vinegar, I changed out the Delta to another brand. You could also use a water softening unit, which replace calcium and other metals with sodium, thus eliminating the mineral deposit problem.
Jan 25, 2010 | Delta & Single Handle Shower Faucet
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe 27.069.EN0 Relexa Ultra Shower Head 5 with Integrated Shower Arm - In Logo
2,662 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
