Question about Intex "" Metal Frame Pool Set (56998e) 56998e
How do you set the 18x48 intex pool with metal poles
Have a pool i bought from a friend has everything except the directions, please help. thank you
  • Intex Master
  • 8,404 Answers
Go to www.intex.com and look for your manual please.
Posted on Aug 04, 2010
I have an Easy Set and using a skimmer. Should I remove the extra intake hose?
Huh?
i am confused... What does a hose have to do with the ability of the pump to move water?
Suction of a pump has nothing to do with an extra hose.
Suction ability has everything to do with whether a filter element is clean or dirty!
These toy pumps have an exceptionally SMALL filter, and need cleaning or replacement OFTEN!
The suction action of a pump should not change, with the attachment of a skimmer: unless... The skimmer is higher than it should be and sucks air, therefore the pump will lose prime!
If you comment back with a little more detail, somebody will be glad to assist.
May 28, 2015 | Intex Pool & Spa
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
I have 18 feet by 9 feet metal frame pool and the water 3/4 up but the poles on the side are bending in how do I fix this?
Sounds like the poles need to be replaced. The pool will probably need to be drained to take the strain off the sides of the pool.
Jun 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
Have a intex 18x48 above ground pool, how much salt to add to it for the first time
If you have an Easy Set pool, should be around 5500 gallons, then the initial salt add should be approximately 135lbs...
If you have an Circular Metal Frame pool, should be around 6400 gallons, then the initial salt add should be approximately 160lbs...
Make sure you only run the pump for 24 hrs to properly dissolve the salt, then you can set your chlorinator to desired time... Start high and work your way down... 10 hrs pump and 8 hrs chlorinate...
Check your chlorine level after the first two days and see if it starts to climb above 3ppm, if it does, lower your cycle time until you can maintain the 3ppm level...Hope this helps you?
Good luck and enjoy your pool!!!
Aug 25, 2011 | Intex Automatic Salt Water System for ...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
I have set up the intex saltwater system. We have run the salt generator for several hours, however the chlorine reads 0. I have added conditioner (thinking this was the issue), however, everything else...
The short answer is add some chlorine. Clean your cell and assure it is operating normally per you owner instruction. Normally, the manufacturer recommends physical cleaning followed by acid wash. Of course use the usual safety precautions when using muratic acid.
Conditioner? Is that Cyanuric Acid? or is this a sequestering agent for removing metal?
Thanks for your interest in FixYa.com
Jul 03, 2011 | Intex Automatic Salt Water System for ...
How much salt to I add to an intex saltwater pool that is 18x48?
all depends on what kind of intex 18x48 straight wall blow up ring and so on
Here is a link to the manuals look up pumps I think it is the top choice even if it is not your filter open it and go to pg 17 and look up your pool it is 135 to 160 pounds depending on your pool
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 19, 2010 | Intex Automatic Salt Water System for ...
How much salt do i put in my pool. its 18 feet by 4 feet round. its the intex salt water system.
for the 18x48, you will add 135 pound (60 kgs) to start. When the Low Salt light comes on you add 35 pounds (15kgs)
May 22, 2010 | Intex Automatic Salt Water System for ...
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
372 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
