Your solution to my problem(Methodical)
Hi Benimur
Thank you for your help with regards to my problem.
Changed the LCD TV as it was still under warranty.
Brought the new one home to find out that the remote did not work!
This time I fixed myself, the connector to the remote sensor in the front of the LCD TV PCB was hanging half out of the socket.
Kind regards
Methodical
    Brigadier General:
  • 6,966 Answers
And Hi methodical,
Am glad that your concern has been attended to and additionally glad that you were able to fix the problem of the 2nd/replacement unit.
Posted on Apr 20, 2008
Hi I am waiting for your help to fix my TV as I have explain to you. Are you there E-mail me regarding my problem. Thank you. Mohammed S. Faruqui 50 cottonfield Cir. Caledon, Canada
Good day!!!!!
Sir may I know again what is the problem of your Sharp LC60LE810UN 60 in LCD TV?..
Please send it to me so that i can help you to fix your TV...
Thank you and have a nice day!!!!!
Jan 05, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Teac lcd tv / dvd combo modle lcdv1501m the problem is it will not play dvd it plays cd ok every else seem fine could you give me some ideas please
Initially, pls try using a CD lens cleaner similar to those used in computer CD ROMs. it is normally readily available from most computer shoppes. The idea is to clean the laser pickup/eye/lens. Should cleaning be not corrective, it may be necessary to open the unit for a look & see or manual cleaning the insides.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 26, 2008 | Televison & Video
Dragon NaturallySpeaking 9 preferred will not work, Microsoft Excel
i do not understand your problem, can you please reexplain
Nov 29, 2007 | Computers & Internet
OIL FILTER CHANGE
d61f742.jpg Benimur
Rank:guru_s.gif Guru
Rating: 87%, 2968 votes
Hi and welcome to FixYa,
Initially, pls check here.
Thanks a lot BENIMUR !!!!!!
Jan 11, 2009 | 2001 BMW F 650 GS
Power board price.
Hi welcomejee,
The 6 or now the 4 are just numbers for us. Its the challenge, the chance to prove oneself is right.
With what happened, you could see all the others were shying away and staying at the sidelines.
Now if only we could find a schematic of an LG/Zenith monitor or LCD TV that uses the same PSU/Inverter board, that would be the icing on the cake.
Cheers and appreciate much the kind words.
Dec 29, 2008 | Dolphin Sun Pro 120 Fishing Boat Bass...
Benimur...
Appreciate the direct "Ask Me".
I understand and no offense taken. Apparently the same source with the same search engine.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Apex Digital AT2014DV 20 in. TV/DVD Combo
KLH DVD 221
My sincerest apologies. I was not made aware that you posted a direct request for assistance. It was only by chance that I saw your post.
To your concern should you still require information; most units would have a yellow, red and white connectors commonly called RCA. What is required then is a triple RCA to RCA connector as shown below. The yellow is normally connected to the video, while the red & white are for the R & L of the audio. An identical set would be on the rear of the TV unit henceforth the connection would be OUT from the KLH DVD 221 to the IN of the TV.
In some instances, a single cable is used to connect some models to the TV. This is called an RF patch cord and would look sonething like below. This would come form the RF OUT of the player to the RF/CABLE/ANT IN of the TV. Pls make sure that the style/form fits your units.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Aug 20, 2008 | KLH DVD8350 DVD Player
Burning oil-no visible leak. Seems as though engine is loosing pressure. sputtering from exhaust pipe. No smoke coming from pipe except on occassions when you hear a rattle and the car loose pressure then...
For some reason the Live Session froze. Our apologies for any inconvenience. Please find below the last part of my posts in case you were not able to view them.
photo7 says:
what about the piston rings
Benimur says:
that could be checked with a compression tester at your dealer
Benimur says:
so for the moment course of action would include: compression test
dye to determine where the oil went, if no trace found then it could be assumed was burned; change the catalyctic converter, it went as a direct result of oil in the exhaust system
Benimur says:
some remedial/temporary workaround includes installation of an aftermarket oil cooler with its own fan; maintain a lower engine temperature by removing the thermostat (not applicable to cold regions) and wiring the radiator fan to continously work.
Jul 28, 2008 | Toyota Corolla Cars & Trucks
Need installation cd rom disk
You can try getting in touch with Lexmark at any of their offices here and request for a second copy of the CD ROM installer disc
or
you can download the appropriate driver software for your specific printer here.
Jun 21, 2008 | Lexmark Office Equipment & Supplies
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it...
where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
May 31, 2008 | Toshiba Computers & Internet
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
