Question about Kenmore 57029 Side by Side Refrigerator
Ice maker not working
We recently moved our refrigerator to another house without a water line connection for the icemaker. When we installed the water line about a week or two later, we noticed the ice maker switch had been left on. We now have water through the door but no water is going to the icemaker. Did something fail because the icemaker was left on without any water connection? Or is something else the reason? thanks
  • 4,070 Answers
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Jul 12, 2010
Ice Maker not working after replacing IceMaker and Inlet Valve. Any other ideas?
Hi. I am sorry that your ice maker is not working. Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
Jun 19, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker is not functioning properly.will not produce ice.Water maker does work.
It is your inlet valve. behind the refrigerator where your water line is connected. Most refrigerators the water dispensor will work without the icemaker. If you have no water entering your fridge into your icemaker then it is your inlet valve
Aug 19, 2010 | Jenn-Air Refrigerators
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
Kenmore Refrigerator 59562990 icemaker worked then stopped
Good day,
Could be air, but if 48 hours passes without ice, it's not the problem.
To trouble shoot the ice maker, it is best to follow a step by step testing procedure. Ignore any step that does not apply.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Feb 17, 2010 | Kenmore Refrigerators
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hooked up waterline to side by side frigiedaire,
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
Water line flows freely on my msd2454gr - freezer is cold - ice maker seems to have electricity to it to levers move and the ice maker lever moves - but never hear water going to the ice maker - i have...
Hi, Yes you can. When the icemaker cycles, do you hear the inlet valve buzzing? If you blew through the line that goes from the inlet valve to the icemaker and it is open, sounds like the inlet valve is bad.
May 17, 2009 | Maytag MZD2766GES Side by Side...
Kenmore 106.53342300-side by side-icemaker not working..at all
IT COULD BE 2 PROBLEMS
1 .YOUR DEFROST TIMER IS BAD.
2. YOUR WATER INLET VALVE IN THE BACK COULD BE BAD.
BOTH PARTS ARE VERY INEXSPENSIVE(USUALLY UNDER 20 BUCKS AND YOU CAN GET FROM YOUR LOCAL SEARS OR ANY WHERE ON LINE. GLAD TO BE OF SERVICE
Jan 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Nov 13, 2007 | Refrigerators
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
