Question about Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card
No sound coming from my computer
Suddenly my computer start playing sound... in the audio property it says no device found... i already installed a audio driver but does'nt resolve the problem..
pls help me
  • songryong Apr 20, 2008
    i already try the system restore but did'nt solve the problem.... and i already re-install it.. but does'nt resolve it also....
I already uninstall it and install a new device but did'nt resolve it, same with the system restore.... and now... i dont how to really do it... pls help me
Posted on Apr 22, 2008
  • 76 Answers
Have you tried restarting your computer? If that didn't work try deleting the program for your sound card and try reinstalling it. If that doesn't work try a system restore, now depending on your operating system the fallowing information my not be accurate. This is for Windows XP Home edition, Click on Start>help and support>system restore. Then it will ask you what date you want to restore it to, then pick a date, then click continue or next and it should restore your system to that date. Hope this helped=)
Posted on Apr 20, 2008
  • Christian Hagner Apr 21, 2008
    Well I'm sorry, thats all i know. =(
No sound from the computer when i play something
Hi
- you must Start from speakers, check that its work correctly.by testing them in another computer or
Audio Device.
- insure that the Sound not muted .!!
- insure a bout Sound Driver from control panel -> Sound Speech and Audio Devices.
or right click on my computer -> properties-> hardware -> device manager
insure that is no yellow (?) question mark near Audio .
- if driver lost re install it and try
if its installed then you must change Sound Card
Apr 24, 2011 | Computers & Internet
My sound card on my desktop PC is not working
If it is on board sound then first check in bios that sound audio device is enable. For that when you power up the computer press F1 or F2 or del or ALt+F2 to enter in bios then go to pci configuration and make sure audio is enable then save settings and exit. If it was already enable then make sure audio driver is installed and working fine. You can check it in device manager. Right click on my computer icon then click on property then click on hardware->device manager then you can see all drivers list then make sure audio driver is installed. If still same issue then uninstall audio driver from start menu->control panel->add remove programs then reinstall driver from disk. If you haven't driver disk then download audio driver from desktop menufecturer web sites then install then it will work fine. If you have sound card installed in PCI slot of cpu then open cpu cabinet then reconnect sound card in another pci slot on motherboard then reinstall audio driver then it will work fine. Also make sure there is not any loose connection on sound jack and speaker cable.Make sure in control panel sound property there are not any mute sound. Play song file in window media player and make sure sound is not mute on it. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Why my sound is not avalable playback and recording devices
If your system is not playing out audio music or even the start up tone then you need a sound driver on your system but if you have a sound driver on the system already and you did not hear any sound coming from your system probably you disable it. Goto start menu click on MYCOMPUTER and from there right click on it and click on properties from there you will click on hardware then click on device manager from the device manager you will found the sound /audio driver then by it right click on it and click enable . that will allow the system to voice out ok.
Jun 14, 2010 | HP Pavilion dv9823cl Notebook
No sound (AsRock P4 Combo)
1.
Check the speaker connections - take the plugs out and put them back.
Make sure the speakers get power.
Test the sound with headphones.
If it is a Laptop be sure the speakers are turned on (Usually an Fn function key).
2.
Load a system restore point from a date before the sound problem started.
3.
Has the audio service been started by Windows?
Click Start > Run > type services.msc - then click OK.
In the new window - Scroll down to "Windows Audio", right-click on it and select Properties.
Another new window - set the startup type to Automatic, click Apply and then click Start.
Have a look in "Play control" and any other sound mixer you may have installed to check if the sound is muted.
Go to Control Panel >> Sounds and Audio Devices.
Check to see if your sound card is listed.
If no audio device is detected proceed to step 5.
Be sure the Volume is turned up (at least half way).
The MUTE box should not be checked (go to the advanced window and make sure that nothing is muted).
Select the proper speaker settings under speaker settings advanced tab.
Set the speaker setup settings accordingly.
Is your sound card the default playback device?
Right click the speaker icon next to the clock >> Choose "Adjust Audio Properties".
Click on the Audio tab and select the correct device.
If you make any changes - click Apply, then OK before you close the window.
If you use another type of audio program, please refer to that program's trouble shooter for diagnostics.
Creative Sound Card owners can try this:
Click Start >> Programs >> Creative >> "Sound Card", for example Audigy >> Creative Restore Defaults.
4.
Check to see if the sound card is properly installed in the Device Manager.
Right click My Computer >> Properties >> Hardware Tab >> Device Manager >> in the "View" menu - click "Show hidden devices".
If there are yellow or red "marks" next to the audio, "Microsoft Universal Audio Architecture (UAA) Bus" or an unknown device - install drivers (see step 6).
If Windows does not detect an ONBOARD (Integrated) sound card >> Check to see if it is ENABLED in the BIOS (Setup).
If Windows does not detect a PCI sound card (an Added sound card) >> Shut the computer down, disconnect power. Take the sound card out and put it back again - if possible, use another PCI slot.
5.
Install available Windows updates, including DirectX.
Go to Start >> All Programs >> Windows Update.
6.
Installing drivers:
6a. Install the chipset driver first >> Reboot.
6b. If a "Microsoft Universal Audio Architecture (UAA) Bus" is present in Device manager >> install the driver >> Reboot.
6c. Uninstall old sound drivers:
Check in Add/Remove Programs in the Control Panel for an Audio device driver (i.e. AC97).
Go to the Device Manager and uninstall the driver (Right click on the device >> uninstall).
Install the sound driver >> Reboot.
The drivers to install can be found on a CD that came with the computer/motherboard/sound card.
Jan 12, 2010 | Asrock (P4COMBO) Motherboard
My lenovo S9, I can hear any sound.what should I do... before it has a sound,but when I re install ( I hv a virus on my netbook s9) and the sound dissapeared....
right click on my computer -->properties-->device mngr-->sound video game controlers: right click on your audio device and update drivers
Apr 23, 2009 | Lenovo Thinkpad T60 Notebook
Problem with sound
HI.... First you need to check the audio propertities. Go to Start->Right click on My Computer->Properties->Hardware->Device Manager->Under sound,video tab check if anything is disabled or if it is showing an yeloow sign... then you need to install the audio drivers again from motherboard CD....
Go to Control Panel and check the Sound and Audio device properties, if it is muted then adjust it properly.... If need some more help plz contact..
Thank you....
Jan 01, 2009 | Acer NSK8458AN Keyboard
H D Audio Driver fails to install
Have you checked to see if the driver is already installed, and the volume is just turned down? (Start> programs > accessories > entertainment > volume control) If so, try going into Device Manager (right click My Computer > properties > hardware > device manager) See if the sound card is showing up there as a yellow question mark or other error icon, it will stand right out. If it's there, right click, and uninstall it. Now (still in device manager) press the button that looks like a computer screen with a magnifying glass on it, that will scan for hardware changes and pick up the sound card, which windows includes the driver for automatically. If this still doesn't work, try downloading from realtek here, and installing that. Hope this helps.
Jul 17, 2008 | Microsoft Windows XP Professional With...
Sound device
i think sound driver is nt installed in ur laptop..
install d driver which is in urs driver cd given wid ur laptop n see d sound comes or not.....
if driver is already installed den see
start>control panel>sound n speech>sound n audio device
cheackd out laptop volume...
do dis n askl me if ur havin more problem...
thanks....
Jun 26, 2008 | HP Compaq Presario V6000T Notebook
Audio problem
You need to install the correct driver for the sound device, because with win XP it can install a generic driver but it wont be working properly so if its a built sound on your MOBO you need to install driver for it from the MOBO setup CD.
May 10, 2008 | ASUS P4XP-X Motherboard
No Sound from Acer 5100 : Volume tab is disabled
I am worried that there is a problem with the sound card on your motherboard. If it has worked in the past and then suddenly disappeared, usually it is because the computer can no longer locate your sound card. It will not load a driver for a device that no longer exists. Since you have already done most of the troubleshooting steps, it is time to think about replacing your motherboard. Good luck
Apr 24, 2008 | Acer Aspire 5100 Notebook
Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
