Question about Frigidaire Washing Machines
Water won't drain out from the spots where fabric softener goes
I have a front loading frigidaire model FWT547GHS and I can no longer use the slots where either bleach or fabric softener goes as there is water in there that does not drain out.
    President:
  • 670 Answers
It typically has some residual water after a load. All you need to do is to remove the detergent dispenser and dump the water out. To remove the detergent dispenser, pull it out as far it will go, then look into the detergent slot. There should be a horizontal plastic tab in the back of the detergent slot. Press the left side of the plastic tab and pull the dispenser out of the machine. Then you can dump the water from the bleach and fabric softener slots. Just slide it back into the machine and your good to go. Hope this helps.
Posted on Jul 12, 2010
Bleach dispenser
Hello friend, I appreciate your post!
I understand your having an issue with the bleach dispenser of your Frigidaire front load washer. I would like to ask a couple of additional questions to better assist you. Is it not dispensing bleach? If you add fabric softener does it do the same thing? Finally, what is your model number so I may be able to proceed further? Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame. Thank you for the post and I look forward to assisting you. -Matt
Jul 22, 2014 | Frigidaire GLTF1670A Front Load Washer
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
The fabric softener and bleach trays will no longer feed into the washer they stay full. Any ideas?
Just wondering by taking the top off & cleaning it would this solution be the same if the fabric softener tray has water in it after washing a load of clothes?
Jun 27, 2010 | Frigidaire ATF6000ES Front Load Washer
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
The fabric softener and bleach tray won't drain
clean the caps sometimes they get clogged and cannot syphone
Jun 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
290 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
