Question about Dometic Rooftop RV Air Conditioner
I have a Carrier A/C with remote. It was recently
I have a Carrier A/C with remote on my RV. It was recently installed to replace a bad unit. The remote will not bring on the furnance. The inside temp at 73 degrees and the heater function set for 80. When I depressed the emergency furnace button for 5 seconds, the heater came on. Why will the heater not respond to the remote?
    Scholar:
  • 66 Answers
I do not know the unit. However, I am willing to make a guess. It sounds as if this may be some kind of heat pump. If this is the case, than when you turn on the heat there will be a time delay to prevent compressor damage. Emergency heat skips the compressor and turns on electric heat strips. If my guess is right, you should be able to turn on the furnace and wait 5 minutes and it will start. I hope I am guessing right and you have no problem.
Posted on Jul 14, 2010
How do you know remote is working?
Fresh batteries in remote? Will AC turn on by manually at ceiling assembly? Little green or red light on at ceiling assy? Have you checked Carrier site for manual to download?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Carrier rv air conditioner
1) replace batteries by new ones type ALKALINE
2) CLEAN the contacts batteries with contacts batteries
3) retight the spring contacts batteries for better contacts.
4) if doesnot work, open the remote.control and clean the keypads contacts from dirty, dust, oxide, or bad contacts or open contacts repair.Remember they send infrared light to the receiver Syscon
5) Otherwise you must go to the repair shop TV for fix it.
God bless you. see the diagram
Jul 29, 2012 | Televison & Video
Replacing the remote control for rv ac/furnace with standard thermostat
You are aware that the ceiling assy (control box) will most likely need to be replaced as well, to work in conjunction with new thermostat. If you contact dometic ( www.dometicusa) and give them your model number off bottom of roof unit and what thermostat you are trying to install, they will advise what is required.
Oct 17, 2011 | Dometic Rooftop RV Air Conditioner
I have a Carrier RV Air V air conditioner. I turn
Have fan start capacitor checked/replaced by licensed tech, or electrician as they are very dangerous to work with if not experienced and can give a very high voltage shock, that could be fatal. They basically store and increase voltage to higher range for start up of fan and compressor.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
I have a carrier 15,000 rv air conditioner with remote control, can I change the bottom unit & hook it up to a wall mount thermostat? My old a/c was hooked to the thermostat so it is wired for the...
Call 1-866-464-2478, Mon-Fri, 8am-5pm.
I see no reason why not, once you have lower unit (control box) and wiring diagram. When you call that number, have your current model number ready of upper unit, and I'd ask for technical assistance. Good Luck.
Sep 16, 2009 | Heating & Cooling
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
Is an old unit worth fixing?
I recommend going with a new one. Both the coleman and the carrier are excellent and a whole lot more efficient that the 16 year old dometic.
May 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
173 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
