Question about Dell Laser Printer 1100
Input 8.5 x 11" single sheet into paper feeder. Press print button on laptop. Dell 1110 sucks paper part-way through paper input guides and ... dies. Ingoing sheet of paper remains hung-up half way through "go-to-print" cycle. Output: frustration!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Try to print with one paper at a time it should work fine
Posted on Jul 12, 2010
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
PAPER WILL NOT FEED
hi there !
you may do the steps below:
-Ensure the Paper Tray is Not Overfilled
-Adjust the Printer Paper Guides
-Locate and Remove Any Obstructions Inside the Printer and Input Tray
-Determine if Multiple Sheets Are Fed at Once From the Paper Tray or Automatic Document Feeder (ADF).
-Verify the Print Media Installed Is Compatible With the Printer
-Clean the ADF Paper Feed Roller
-Reseat the Dell Printer Power Adapter
-Try a Different Type of Print Media
*If all else fails
-Replace the Dell Printer
cheers!
Oct 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
White bands on color photo prints
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Paper is feeding unevenly on black & white prints
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
May 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper feed on Canon i 350n ink jet printer
Ensure that:
May 13, 2008 | Canon i350 InkJet Printer
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
101 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
