Question about Atari 2600 Console
Just bought an Atari2600. It does'nt work. I don't know if the problem is the Power adapter or the Internal Power jack. I found out that the internal power Jack is part # 79-5918 but I don?t find it anywhere. Is the internal connector jack suppose to be weld to the console? Mine is kind of lose
    President:
  • 846 Answers
You are correct the internal female connector should be soldered onto the main board. If it is loose then chances are that is the cause. You will not be able to find a replacement as they quit making them along time ago. You can keep an eye out on ebay or amazon.com and you might get lucky.
Your second best bet would be to find a broken Atari 2600 and carefully remove the power connector from it and carefully solder it onto yours. Some basic knowledge of soldering will be required.
Post back if you have any questions or comments, we will try to help you in any way we can.
-Daniel
Posted on Jul 12, 2010
  • htb877 Jul 12, 2010
    Thank you, Daniel. My husband bought it on Sunday. He was so excited but the unit doesn't work. I just wanted to give him a surprise trying to find out what the problem is. If I don't find the internal connector jack until next week, he probably will need to return the Atari.
I need a n ew DC power jack for my pandigital
Most of the Pandigital tablets use the power adapter APR001 which provides 5V at 2A. This is available from Geeks.com here: http://www.geeks.com/details.asp?invtid=APR001 . Other vendors may also have the adapter.
If you need to replace the jack where the adapter connects, try Radio Shack or http://www.mcmelectronics.com . You need to measure the existing jack dimensions carefully. (This ensures that the adapter will connect properly.) When you desolder the old jack and solder in the new one, make sure that you keep the polarity the same. (Otherwise the adapter may not work.)
I hope this helps.
Jan 22, 2013 | PANDIGITAL 7 Android with 2GB Internal...
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
I need a wireless pci cardslot for my toshiba satellite m35x s109
Don't waste any more of your time trying to find one. Even if you found one, you more than likely wouldn't be able to get it to work well with a modern wireless router. Get a wireless USB adapter instead. You can get them for less than $10 from just about anywhere and it will actually work without hassle with your wireless router.
Jul 05, 2012 | Toshiba Computers & Internet
Loose power adapter
Loose Power Adapter or loose internal dc power jack where the adapter plugs into the computer? If the Power Adapter is loose buy another one. If the internal DC Power Jack is loose, you will have to take the laptop apart to repair it. The DC Power Jack is on the motherboard and most times it is soldered to the motherboard. That means you will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrest which hold it in place and has a cable harness that plugs into the motherboard.
Mar 29, 2012 | Computers & Internet
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
My Dell insperion won't power up at all. I bought a new battery and tested the charger and am getting the 19.5V that I am supposed to get. I don't know how to test the battery to see if it is...
If working should turn on with adapter plugged in, maybe the internal jack is broken, move adapter plug around slightly and see if it moves at all, should not. Does any lights com on or do you hear the fan ?
Nov 01, 2017 | Dell Inspiron 1150 Notebook
Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
Sep 06, 2010 | HP Compaq 6735s Notebook
Will not turn on with good battery.
Can you not detach the lead to the charger unit, and plug that directly to the camcorder, to see if its the actual camcorder at fault ?
Near the camcorders power socket, you should see a small picture telling you what power the cam uses - usually around 7 volts, centre positive connection jack plug, at around 900mAh. As long as you get the voltage close, and have enough amps behind it, it will still work safely.
Camcorders are rarely fussy about the exact voltage, but you should never go above 9 volts unless its needs more. Most take the internal power down to 5 volts inside anyway.
The batteries do have a tiny non-replaceable internal fuse, triggered by voltage spikes or overheating, and if that goes, it usually means buying a new battery :(
Batteries can go at any time from the very first second they are used. I've bought many, and had a few that didn't last 2 months from brand new. One high-end type lasted over 9 hours on its very first charge :) and then never worked again after that :(
Apr 03, 2010 | Canon ES8400V Camcorder
My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Feb 04, 2010 | Computers & Internet
HP dv1000 will not boot, no power. Is this a hard
No Power at all sounds like the Internal DC Power Jack that is soldered onto the motherboard is bad. Send it to these guys www.generalsystemsconsulting.com
Mar 08, 2009 | HP Pavilion dv1000 Notebook
Atari 2600 Console Logo
339 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
