Question about Jensen VM9410 Car DVD Player
My dvd player wont accept discs - Jensen VM9410 Car DVD Player
  • Jensen Master
  • 17,130 Answers
It is possible your dvd mechanism or drive has failed. please remove the player carefully , open the top and check from the point of transit to the slot for the head spindle. check for any dirt/dust/ particles stuck around to prevent smooth transport. look for the loading motor mechanism, drive for friction. correct settings. However is all the mechanism seems in order, then you will have to check on the motor drive, check for signals fromt the processsor to confirm failure of the drive- see if +B is coming to the drive. If not replace. Once the cd goes in , it should land on the spindle and start reading. Helpful.? Good day
Posted on Jul 13, 2010
Pioneer cd player pdc-q180 wont turn and ejects disc, any advice??
have a look inside to see if any forien objects are in the area.otherwise the unit needs to go to a specialist.internal driver unit could be faulty.
Aug 14, 2014 | Televison & Video
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
Will not accept DVD -R or DVD +R discs . Will play DVD-r RW. Shows "Insert Disc"Cyberhome 402.
Found out on another site that Cyberhome DVD player will only accept certain makes of disc and always struggles with DVD+R. Their was a Firmware update which supposedly solved this problem but this is no longer available, It's old anyway and was very cheap - will buy a new player!!
Sep 06, 2009 | Cyberhome CH-DVD 402 DVD Player
My polaroid dvd player keeps reporting "Bad Disc" on discs that play just fine in other DVD players. What can I do to fix this problem?
Is the movie a copy or an original, some copies do not work in all machines, some will accept a dvd-R but will not work with a dvd+R except if you have a brand new unit, they usually accept most discs, the older dvd players are not compatable with all blank dvd's...Steve
Jun 13, 2009 | Polaroid PDM-8551
Won't accept dvd after loading!
DVD door switch is bad. If you are willing to open it up and soldiering a new one, here is a link to a replacement switch.
Jun 11, 2009 | LG XBR446 DVD Recorder/VCR
Failure to accept DvD Ram discs in a Panasonic DMR-E55 Recorder
Possibilities are that the laser lens needs cleaning (use a proprietary cleaning disc) or that - as long as you are sure you have original manufacturers' discs and not fakes - the discs are scratched or dirty.
Feb 20, 2009 | Panasonic DMR-E55 DVD Recorder
Plz help!!...i have recorded a home video,and transfered it from vhs to dvd using the funai HDR-B2735 and dvd-R discs,but they wont play on any other machine?
Hi have you finalised the discs on the dvd part of combi? If you do this they will play in other machines that accept dvd-r
Jul 01, 2008 | Funai DV-220SL8
Dvd writer wont accept dvd-r
If you have posted the correct model of writer, then it only supports the writing of DVD+R and DVD+RW discs, but CD-R and CD-RW disc writing are supported, and it should play all forms of DVD, so it won't burn DVD-R and RW discs, but if it wont play all types then try a cd/dvd cleaner, but to be honest when writers start playing up the lens is normally faulting and a replacement drive will be required.
Jun 18, 2007 | HP DVD Writer (ds703a) (DS703A) DVD+RW...
Jensen VM9410 Car DVD Player Logo
160 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
