Question about Kenmore 24032\24036 Top Load Washer
No dranage My washer is not draining water after washing cycle. It happened after I wash my bathroom mate.
  • oldguy5 Jul 12, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. WILL IT SPIN???? CAN YOU HEAR THE MOTOR??? DO YOU HEAR / SMELL ANYTHING UNUSUAL??? IT SOUNDS LIKE A CLOGGED PUMP, HOSE OR TUB OUTLET BUT WITHOUT KNOWING THE MODEL NUMBER, I'D HESITATE TO TRY TO GIVE A SOLUTION YET.
  • ifte_yusuf Jul 13, 2010
    MOD # 110.25062500 Type 170
    Yes, It spin.
    No Smell
    Yes, You are right, It is CLOGGED some where. It happen after I washed my heavy bathroom wool mates. The washer operate but it does not drain. I don't know where it is clogged. Is there any filter that I need to clean?
    Thanks for you help.
    Problem Solver:
  • 6 Answers
Check lid switch
Posted on Jul 12, 2010
Testimonial: "Thanks for your help."
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.25062500&pathTaken=partSearch
Next, see the following for how to remove the cabinet and get to the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=2e6a5f8005d1999210755936fc7d072e
I'd pull the pump and check inside for any blockage. I'd also pull and check the hoses as well as the port in the tub that connects the hose to the pump.
Posted on Jul 13, 2010
On a Maytag Maxima XL front load washer, please tell me on what cycle to wash a bathroom rug. zo vs
the heaviest cycle there is . but it sounds like the control board is not advancing the timer if it sits that long on one thing perhaps a call to a repairman is called for .
Jun 22, 2015 | Maytag Neptune MAH5500B Front Load Washer
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My whirlpool washing m/c 1400rpm awo/r 5406 will not complete the wash cycle it washes until it gets to spln and drain then the service light comes on (spanner)washer stops working but water still flo
locate the dranage water pump, screw it ou nd clean or check on the filter cuup,,always situated next to the water pump below,,u can trace the pump along with the outlet
drainage tube
Jan 26, 2015 | Whirlpool Washing Machines
Washer is not spinning during the drain/spin cycle...so the clothes are really wet when its finished
the washer will not spin if there is still water in it. the issue may be with the pump, I would look at the dranage see how it is flowing, make sure there is no restriction there, then I would look at the pump take it off have a good clean out of it.
hope that helps a little
Colin
Sep 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Washed a load of floor rugs now washer will not drain
sorry but one rug is ample for any machine,but the load weight alone is far to much on the machine,i have been in a testing factory and seen the things people put in machines and it would shock you,but back to your presant problem?basicly the whole dranage system is full of heavy dirt and needs cleaned badly.Try putting two dishwasher tablets through machine and see what happens but i must say i wouldnt have high hopes,i would think lower dranage pipes are going to be cleaned.if you want my help come back to me.adrian,,,,,,,
Aug 21, 2010 | GE Profile WPRE6100G Top Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not drain . I washed bathroom rugs that fell apart leaving excess fibers that I beleive plugged up the holes that allows drainage. A few gallons of water is still sitting in my washer and...
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
170 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
