Cannot print. Your solutions are not solving the problem.
  • 6,826 Answers
If the printer cannot print it can be because of a number of problems.
First, the printer ink may be out.
Second, the driver for the printer may not be installed correctly, and requires uninstalling and reinstalling.
Third, the paper may be jammed or out.
Posted on Jul 16, 2010
Print spooler is not running
Please try these steps:
  1. Browse to Start -> Run... and type NET STOP SPOOLER (this will stop the print spooler service)
  2. Type NET START SPOOLER (this will restart the print spooler service)
Try to print again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1150 All-In-One InkJet Printer
Only printing 7%
If you're using Windows, it could be that your Print Spooler is not running properly. Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. type in NET START SPOOLER (this will restart the print spooler service).
Try to print a document again to verify that the problem is fixed.
Oct 10, 2011 | Lexmark X4650 InkJet Printer
I have changed the ink cartridge but it still prints very light. Should I clean the printer head? If so, what is that and how do I? Thanks,
For laser printers there is no print head as such to be cleaned as in ink jet printers.
There are however many causes & solutions for fuzzy or light print issues.
The best solutions can be found on HP's website itself. Click on the link below which will take you to step by step solutions which will more than likely solve your problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00599279&tmp_task=solveCategory&lc=en&dlc=en&cc=uk&product=439320&lang=en
If the solutions from the HP web page don't solve your problem it may be neccessary to take your printer in to an authorised HP repair shop.
However, if the solutions are followed step by step, I am confident your problem will be solved.
Best wishes,
Graeme
Mar 22, 2011 | HP LaserJet 1020 Printer
My printer will not print. There were no cartridges in it for about a year. I have installed new cartridges but it will not print.
There are several solutions depending on what the issue really is. The simplest of them is to run the print head cleaning wizard, which comes with your printer software installation CD. This have only a slight possibility to solve the issue, but since it's very simple, you can have a try.
The next solution is applicable when you have ink clogged in your print head. It may happen due to several reasons like leaving the printer unused for a long time or if the print head was kept in inverted position during packing and storing etc. In that case, remove the print head, and place it in warm water (1/2 to 3/4 inch) for a few minutes. Care should be taken to avoid too much water getting into the print head. You will see ink leaking out to the water. Take the print head out and put it back in the printer after wiping and see if it works. You should try a few test prints as the first few prints will not be clear due to the water in the print head.
If none of the above two works, then you can't go for a economic repair. The best thing now is to replace the print head. But, before doing all this, try contacting your dealer or the HP, if the printer is still under warranty. They will solve the problem for free if it is so.
Hope this will solve the issue. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | Lexmark X5150 All-In-One InkJet Printer
Solution for printer
* Does the same issue persists while printing from all applications?
* Does the unit print the self test page properly? Steps are given below
* Make sure the printer is loaded with unused white paper.
* Press and hold Cancel on the printer control panel.
* Press Start Color Copy .
* Release both buttons. The self-test page prints.
Please get back to me with the above information. I can solve this problem....
:) Dr Tony
Apr 04, 2010 | HP PSC 1410v All-in-One Printer
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's...
you can solve its by replacing the Cartridge Unit.
othewise a solution available in my side. You can refill your cartridge until when the cartridge unit damaged.
if you have internet connection i can clear it through internet.
Feb 22, 2010 | Samsung SCX-4300 Monochrome Laser...
Cant print pdf file - get first page only
Just to show I'm for real here's the solution
Document security settings dissallowed double sidded printing.
Solution: Return document to author for security changes or just print single sided.
It worked - I did both
Mar 30, 2009 | Toshiba E-STUDIO 850 Copier
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
Error 6000 is shown!!!!!!!
whenever it try to copy scan or print by canon pixmamp150 printer it shows error 5?please give me a solution to solve this problem.pleeeeeeeeeez
ayman refaie
ayman_refaie@yahoo.com
Feb 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
13 people viewed this question
jasbo
jasbo
