Question about Dell Microsoft Windows XP Home Edition
The margins are too large for the computer screen, this became a recent change when att.com switched over. I am on a dell computer and have not had this situation before. Thanks
  • 1,675 Answers
Hi this sounds like your resolution has set back to a smaller setting, ie 640x480 or something in that region, you need to right click on your screen anywhere apart from an icon, go to properties, then settings , look for the resolution setting and change it to a higher one, that should do the trick, dont forget to save the settings or it will revert back to the older one again hope this helps if not repost and i will see if there are other things ok..cheers
Posted on Jul 12, 2010
How do I fix black screen on my Dell desktop?
I have downloaded Software <---------- did you download or did you install?
the computer became black screen? <----------
Terry
Feb 19, 2015 | Dell Computers & Internet
My wifi for some reason became disabled, how do i enable it
without further information it's hard to tell but most laptops have a physical switch, others have a function key. Look for the wifi icon on a switch or keyboard key, dells use F2 for that.
Oct 18, 2013 | Compaq Presario Cq-62 15.6 Laptop Lcd Led...
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
Ps3 screen margins too wide for tv display
Try holding your power button on your ps3 down till it blinks.(not your main power switch on back of console) I do believe if correct, this should reset your ps3 resolution to an auto set for best display on your tv. It may pop up with a message on resolution, but that should work. I had similar problems and that worked for me.
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
After reinstallation screen became blur
After installing XP, did you install the drivers in this order?
Notebook system software Chipset Utility Video Driver Audio Driver Network Driver Wireless driver Touchpad applications also run the cleartype tuner http://www.microsoft.com/typography/cleartype/tuner/step1.aspx
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Had to reinstall my OS, now I can't use the internet
Be certain that you have downloaded the correct drivers. Find your hardware by booting with F2 then view Devicesviewting!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} p {mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here's the link for your Inspiron:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=INS_PNT_6000
Hope this helps
Sep 03, 2009 | Dell Inspiron 6000 Notebook
Hp Compaq FS7600 17" monitor screen adjustment needed
Um, lets see. Does any of the buttons work? Try and find a button that will switch settings back to factory default. If not go to control panel and change the screen resolution to see if that helps in the mean time.
Jun 26, 2009 | HP Compaq FS7600 17" CRT Monitor
Monitor Display
it sounds like you have change the postionof the screen on the monitor. try changing the horizontal and the vertical setting to remove this
May 22, 2008 | Dell 828FI 15" CRT Monitor
Can't change monitor display settings
no drivers are needed for monitor. Its the video card drivers that you should look for at the dell drivers and downloads website. make sure that you have the right driver installed so that you may be increase your screen resolution.You may also use your Dell Resource CD Drivers and utilities. Install the Resource cd, On the TOPICS dropdown box, select drivers,You'll know which drivers needs to be installed because they will have a check mark infront of the correct device driver. Clicke extract button after you have chosen the video driver. You may need to scroll down.Restart the computer.
Feb 15, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell Ultrasharp 2005fpw
The problem you are describing is definitely a bad picture tube.please replace it or the problem you are describing sounds like high voltage regulation problems. The easiest way to tell is by changing from a black raster to a white raster. If the size changes quite noticeably or jumps alot then you have a regulation problem. The first thing to do is check your high voltage while changing the raster from black to white. If the HV varies by a large margin, then you have a flyback problem. If it doesn't, check the voltage at the collector of the HOT while varying the raster again. If the voltage changes alot then check your B+ line. Typically what goes out in this case is a capacitor(typically 100uf-350v or so) or the B+ regulator. Hope this helps.
Jan 26, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Computers & Internet Logo
44 people viewed this question
Clive
Clive
Alun Cox
