My maytag top load model number mav3855aww bangs around whe spinning.
  • 1,284 Answers
Hi, these machines have a common fault. If yours has no visible filter, the filter is in the rubber waste tube, just below the drum.
Most faults on these machines are due to a blockage or build up of sludge and lime scale in this area.
This also affects the pressure switch, which is linked by a plastic tube to the same place! This will cause the machine to stick, and not spin, or to spin with water in the drum causing vibration.
Firstly check the outlet hose and the plumbing where the outlet goes to for signs of sludge and lime. Unless you have very soft water or a water softener, there will be some! Usually lots!
Clean this out.
Disconnect the machine from the mains and the water supply and pull it into a clear area.
Put a thick cloth on the floor and gently lay the machine on its left hand side, looking from the rear,
Undo the small panel on the back and you will see the black rubber concertina hose, pressure chamber and pump, which are now all easily accessible from the rear and the bottom of the machine.
Undo the circlips with a screwdriver and the special plastic clips with a pair of pliers by twisting each part in the opposite direction.
Take the whole hose off. You find a filter and a "ping pong ball" inside this.
Clean it all out as thoroughly as you can. At the same time clean out the plastic pressure chamber and the pump. you might need to use a proprietary limescale remover or vinegar to do this.
You will usually find a few buttons, plastic items, paper, couins and a load of sludge!
Put the whole lot back, The plastic clips slide together with a toothed grip.
The whole job should take about half an hour and the machine will be like new.
Take care
Posted on Jul 12, 2010
Maytag MVWC400XW banging during wash cycle
1) try to get the model, name, serial number, from the washing and call to maytag, get the support ONLINE via phone or chat, and give you information from the washing machine, and explain, they will have the record from your washing machine, and guide what the next step for warranty. this the web www.maytag.com
God bless you
Jun 29, 2012 | Maytag Centennial MTW5800TW Top Load...
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Cycle stuck on 23 minutes and keep repeating cycle
If you do a Spin Only cycle with that wash load will the machine Spin up?
If not any error code?
Does the wash Tub bang around with a Spin Only cycle?
Do you want to DIY the fix or call in a repair service?
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Will spin empty but after half load ...stops
Any error codes with the fail to spin? Is the wash Tub banging around in Spin Cycle of the Wash Cycle?
Oct 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune top loading washing machine when washing sounds like there are belts squealing and the washer tub seems to hit the sides of the machine when spinning what is going on?
This sounds like a possible Clutch issue. Is the machine model an FAV6800A or FAV9800A?
When the washer is banging around do you take unbalance errors such as dC or uC?
Do you want to DIY the fix or call in a repair service. If you could confirm your machine model number......Rich
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Oil in
your transmission is leaking or you have bearing/seal problems
Nov 11, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
