Question about ViewSonic VX900 19" Flat Panel LCD Monitor
We had a power outage and the monitor wont come back on. Verified the power cord is plugged into a live outlet. We dont get a green power light
  • 11,361 Answers
Marshall sd monitor wont power up
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your Monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | Marshall Electronics V R84DP SD 84 144...
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Acer Computers & Internet
How do i factory reset my NEC LCD1712 Monitor?
Good luck.
Jul 22, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Computer wont turn on
taking out the battery resets the settings on the bios for the motherboard.
worked for me on the few computers that wont turn on.
If it starts up, you may need to enter dates etc onto the bios.
May 29, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Computer wont turn back on after power outage
Try unplugging the cord from the back of the computer for about 5 minutes and then try it again
Apr 14, 2009 | Compaq Computers & Internet
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Computer power outage problem!
Your power supply is bad--you will need to replace it.
Jan 07, 2009 | Computers & Internet
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Computers & Internet Logo
128 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
