Question about Boating
90hp yamaha outboard. Oil alarm goes off but doesn't need any. Goes off while idleing and moving slowing. What could be the problem. Wont go off unless I move throttle back and forth for a bit. THen it stops and the engine runs smoothly again.
  • 41 Answers
SOURCE: Rough idle 2 cycle outboard
sounds like u need to do a tune up on it. clean the carb, new plug
Posted on Nov 25, 2008
  • 840 Answers
SOURCE: 2003 Jeep Liberty Electric Mirrors only move a tiny bit then stop
it sounds like the switch is going bad in the mirrro switch on the driver door should be able to get on at any dealer it should be any fix
Posted on Jan 25, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 187 Answers
SOURCE: outboard motor idles but will not speed up
You really have to blow out the jets to clear any varnish left over from lay up.
Posted on May 13, 2009
  • 77 Answers
SOURCE: T50 4stroke yamaha outboard
that engine should be electronic ignition, so I would suspect your problem is your coils.
Posted on Jul 12, 2009
Have a 2 stroke 225 Yamaha outboard. Alarm for what I can tell for heat, an oil went off today. Runs fine at lower rpm, but goes off when it goes up beyond 21 rpm.
How long has it been since you changed your water pump? The pressure relief valve can also cause over heat issues if it is stuck.
May 12, 2017 | Yamaha Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2016 | Motorcycles
1994 Yamaha 150HP Outboard
Good Afternoon BayouNola,
This Sounds Like A Loose Connection Problem,
The Tach Is Directly Related To The Charging System,Please Check Your Battery Terminals ,Clean And Secure Tightly To The Battery,
Unplug The engine Electrical Harness Check Clean And Re plug,
Check The Main Fuse For Corrosion And Rectify If Necessary,
If The Engine Was Getting Hot The Alarm Should Be A Continuous Alarm, If It Is a Intermittent Alarm It Is Oil Related !
If In Any Doubt Run With Pre Mixed Fuel,( 500 Ml's In 25 Ltr's Fuel) Until The Problem Is Solved.
Good Luck Gordon
May 07, 2014 | Boating
Help with my 1994 Yamaha 150Hp
Outboards have thermostats...the tattle tale can be pouring water and the engine still overheat if the thermostat is stuck or airlocked.
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Nov 09, 2012 | Clymer Marine Maintenance and Repair...
I have a 98 yamaha 150 2 stroke outboard engine, when cruising about 23 mph she runs fine, but when i run her faster a alarm under the dash goes off in which i will slow it down to idle and the alarm will...
Although water is seen thru the tell tail hole, your engine is overheating. When were the thermostats replaced last? Water pump impeller may also be fatigued, and not pumping enough at high RPM's.
May 11, 2010 | Boating
Hello, I have a Yamaha 9.9 outboard engine, it stars without any problem. When I ref it up just above idle it dies after a few seconds. There is fuel, fuel filter in the line is no blocked.
Yamaha outboard that runs fine until heat light come on and it idles down. When light goes offf it runs fine. What is causing heat problem
Jun 06, 2009 | Yamaha Water Sport
90hp 4 stroke suzuki outboard how do i reset the oil alarm?
TO RESET:
1. TURN IGNITION KEY ON
2. PULL OUT THE EMERGENCY STOP BUTTON 3 TIMES IN TEN SECONDS, A SHORT BEEP WILL BE HEARD IF CANCELATION WAS SUCCESSFUL. TURN KEY OFF AND PUT EMERGENCY STOP LANYARD BACK ON ITS BUTTON
Apr 11, 2009 | Sport & Outdoor - Others
Boating Logo
179 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
