Question about Tascam Audio Players & Recorders
Tascam midstudio 644 powers up and can rewind and fast forward.
It will not play. As it tries to play the tape does not spin. It looks like it wantys to work but wont start turning.
  • 17,130 Answers
You have not mentioned the model. Hope you have checked the belt and the motor that drives teh main capstain and the reel drives. If this does not work then replace and proceed. Also the pinch roller could be defective and not holding pressure to the spindle. Check the roller for hardening of the rubbers. replace if this is faulty. I hope with the set loaded with a tape you can find which drive is not spinning to take up. This should be able to confirm you with the right section. Hope this helps. Good day
Posted on Jul 20, 2010
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
I have a Tascam 488 mk II that will rewind and fast forward, but will not Play or record. Does anyone know a solution to fix this problem?
Check too make sure that the tabs on the cassette itself are there if they are gone place a piece of tape over them, then try recording again. It may be a belt issue open the unit and see if all the belts are present cassettes usually have 2 or 3 separate belts one controlling the fast forward and rewind and another for record and play more than likely this is the issue, If so belts for these units are obsolete try searching science and surplus magazine catalog they carry a variety of large rubber band / belts you may get lucky and find one there good luck I hope this helps you
Mar 31, 2015 | Tascam 488 MKII Portastudio
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Tascam 644 When I press play it won''t stay on play, it stops. It will rewind and fast forward but that too stops by itself.
Scott has a point. You need to determine what is causing the unit to stop and it could be a bad cam motor belt if it has one or the lack of take-up die to the bad idler or even a dead spot on the reel motor. The reel motor will work normally at high speeds due to inertia but at low speeds as are used in play the dead spot of the motor can become much more apparent.
Sep 17, 2010 | Tascam 122MKIII Single Dual Cassette Deck
My Tascam 244 at first attempt to play will not
This sounds like the drive belt has weakened with age. Will have to be replaced.
Feb 19, 2010 | Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 644 midistudio tape deck problem
Halo I have the same problem. The motor that moves the tone heads up only shake a bit but dont move it up to the tape.
The take up clutch motor does not move at all and there is no volt on the motor.
Did you find a solution?
Greatings
Fredrik
Jul 06, 2008 | Audio Players & Recorders
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
231 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
