Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Heater is off-line - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
  • Stephen Dorje
    Stephen Dorje Jul 13, 2010
    Are you talking about the RS Online indicator on the control panel?
    Scholar:
  • 78 Answers
If you are talking about the RS Online indicator, this just means you are not hooked up to a "RS Control system" aka remote sensor or control. Does the heater work?
Posted on Jul 13, 2010
When heater works electric line trip off
You're drawing more amps than your line is equipped for. Rather than modifying your electric, unplug something on the same line to reduce the current draw.
Dec 18, 2012 | Sunbeam SCH2101UM Ceramic Electric Heater
Laars N G pool heater keeps shutting off then restarts
check gas pressure and the size of your line if too small a line and too long a run from the meter it will run out of gas in line then line fills back up heater fires and drains line again
Jul 25, 2012 | Teledyne Laars Laars Lite2 Heater 175000...
I have the espree 536 jacuzzi tub. which heater is required for this unit. i ordered the s750000 but it is the wrong one
you will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
Jan 16, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
In line heater will not light up when turn on
You will need to check where it is installed and compare that to the model number of the heater. A vacuum heater must be installed in front of the pump on the suction line coming from the suction cover inside the bathtub. If you have a WOW pump then that style of heater will not work in the suction line because the pump doesn't have enough '****' to operate the vacuum switch.
A pressure heater is installed in the pvc piping after the discharge of the pump. anywhere in that line before a the jets.
Jan 03, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Heater problem, not very hot & not switching from defrost to floor
either the AC\Heater panel switch on your center dash or the heater box vent door is stuck or not operating. Most likely panel switch or disconnected \ broken vacumm lines at back of switch
Jan 13, 2010 | 1996 Chevrolet Blazer
Need the removal procedure for the G6A-8E RV water heater.
SHUT OFF ALL ENERGY SOURCES TO HEATER. REMOVE ELECTICAL SUPPLY LINES AND TAPE THEM OFF. DRAIN WATER FROM HEATER. REMOVE AND CAP WATER LINES. TURN OFF LP. REMOVE AND PLUG LP LINE. REMOVE SCREWS FROM OUTSIDE CIRCUMFERENCE OF HEATER. PULL HEATER OUT.
Aug 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
We just replaced the propane gas line. Our stove is gas and it lights, but neither of our gas water heaters will light. Both water heaters are new and have been working for about 4 months before the...
You have to purge the air from the lines.
At the water heater, take a wrench and loosen the gas line until you smell gas coming from the line. Then tighten the gas line. Check it for leaks with a soapy water solution. Let the gas smell clear, then light the pilot on the heater.
May 25, 2009 | Heating & Cooling
Heater core metal line to rear heat
need to change cooling lines for 2003 kia sedona,need diagrams
Dec 30, 2008 | 2003 Kia Sedona
Wiring two heaters off the same 240amp power source
FIRST YOU MUST DASIEY CHAIN THE 12-2 FROM THE PANEL TO FIRST HEATER IN THE LINE AND THEN TO THE SECOND HEATER IN THE LINE, ENDS OF BOTH WIRES IN THE SAME END OF HEATER,BREAK ONE SIDE OF THE LINE THROUGH THE THERMOSTAT AND TO THE ELEMENT OF THE FIRST HEATER AND THE SAME FOR THE SECOND HEATER BUT IN THE FIRST HEATER YOU WIRE IN TH LINE THE 2-BLACK WIRES AND THE 2-WHITE WIRES WILL STAY CONNECTED WITH WIRE NUTS AND YOU WILL CONNECT THE THERMOSTAT WIRING UNDER THESE SAME WIRE NUTS AFTER YOU STRIP THE ENDS OF BOTH WIRES ENTERING AND EXITING THE FIRST HEATER TREAT EACH HEATER AS IF YOU WERE ONLY WIRING ONE HEATER ONLY DIFF 2-BLACK AND 2-WHITE WIRES STRIPED OUT AT FIRST HEATER IN LINE FROM PANEL TO ACCESS AND CONNECT FIRST HEATER ,BB HEAT 250 WATTS PER FT
Nov 11, 2008 | Electrical Supplies
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
150 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
