Question about HP Pavilion zd8000 Notebook
Ram upgrade can i put 4 g of ram on my zd8000?
  • 589 Answers
No, the maximum RAM for that machine is 2gb of PC2-4200 type memory.
Posted on Apr 20, 2008
I nned to increase the possibilities of grafic card for working with programs that have image treatment and others and need a better grafic card
In your case, you can upgrade your system ram or memory bu not the graphic card.Upgrading your system ram or memory will boost your application loading and performance. Example your memory right is 1GB so make it 3GB by purchasing a 2GB ram. You will see the difference but do not expect to for the graphics just for faster loading and better performance can only give your memory. Have a nice day.
Mar 26, 2011 | HP Pavilion zd8000 Notebook
I upgraded my hp pavilion zd8000 to 2GB of ram. When I try to load windows XP, I get a can not format disk error. I removed 1 GB of memory and added 250 K in it?s place and everything installs and runs OK....
what service pack are you running ? if you have service pack 3 installed you can not reinstall the OS period , you'll have
to remove the service pack 3 and go back to service pack 2
ram and the HDD don't have any connection with the OS
you can try switching out the ram to another computer for
testing and for checking the DIMM slots on your computer
if its a notebook there will be only 2 slots if its a PC you may
have 4 check your manual for 1234 configuration they never
go as 1234 its usually 1324 , windows XP 32 bit edition will only
hold 3072 MB of Ram while the 64 bit edition will hold up to 8
gigabytes .
Mar 11, 2010 | HP PAVILION ZD8000 SEREIS 100GB (4200...
How do I install a new memory card?
Thats real easy one, open up the Flap covering the RAM underneath the PC, you will see a "Strip" of RAM, carefully pop that out, take care to not touch the Gold Fingers, now have a look at the Description & Numbers on it, now take that strip with you, to the "Memory Shop" :) and select another Strip (Called a DIMM) that is compatible with it. Now simply clip them back into the slots where you removed the first one, they can only go in one way, and can put any DIMM, anywhere, and replace the flap. Turn on the PC, it will automatically "Find" the new Ram & just work.
Feb 24, 2010 | HP Pavilion zd8000 Notebook
RAM Problem
ITS A PROBLEM WITH THE RAM.
REPLACE THE RAM
IF THE ISSUE IS STILL THERE THEN WE NEED TO CHANGE THE RAM SLOT . WE WILL TAKE THE LAPTOP FOR RAPAIR
Dec 12, 2009 | HP Pavilion zd8000 Notebook
Just added two 2gb of ram to my zd8000
Well If its windows xp 32bit OS then it only reads 2.5. I run xp x32 bit with 4 gb ram and i only list 2.7gb ram. Its nothing to worry about. Your system is actually using all of you ram even though windows isn't posting all of it.
Aug 05, 2009 | HP Pavilion zd8000 Notebook
I have a HP laptop model Pavilion ZD8000 and I want to
The specs for the ZD8000 says it supports up to
1GB DDR2 SDRAM 400MHz
Jun 28, 2009 | HP Pavilion zd8000 Notebook
Startup failure and beeping, 4 or 3
your new ram might not be compatible,try to leave old ram and turn on computer
Oct 10, 2008 | HP Pavilion zd8000 Notebook
HP pavilion zd8000 start-up problem.
Try to unplug all the PCI cards and boot, if its still doing it check the ram. If its still doing it check to see if the power supply is good. If all that fails, It could be eather a bad mother board or bad processor.
Oct 03, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Upgrades
i have the same laptop. though your video card is independent, it is still integrated into the system and cannot be upgraded, your only be there is to go to the Radeon website and download the latest drivers for it.(it helps) As for your Ram, you can only upgrade to 2 mb of ddr2.(on mine it made a noticable difference) As far as the hd goes i believe sky is the limit, i went from 100 gb to 160 no problem
Sep 22, 2008 | HP Pavilion zd8000 Notebook
Ram upgrade
No, it will only accept up to 2GB (two 1GB chips)
As for the Vaio, it seems there is only one processor available for this system and it can be seen here
http://product.pelltechnology.com/Sony_Vaio_VGN-FS840W_CPU_Replacement.asp
MOST of the time, it is not practical to upgrade a laptop since it costs so much more in parts and labor than a desktop does.
Apr 24, 2008 | Sony VAIO VGN-FS840/W Notebook
HP Pavilion zd8000 Notebook Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
