Question about Faber Cristal HC 598041 Kitchen Hood
Faber cristal range hood....bulb replacemnt
Faber crista slide outl range hood....florescent bulb 15w replacemnt dosen't light up whole light...starter issue? Also now fan not working- switch is loose and looks broken...can that b replaced?
2 Suggested Answers
  • 833 Answers
SOURCE: Fan Not Working
Sounds like a motor problem...but not necessarily. Cut power to the unit. Expose the motor assembly. Turn the fan by hand...if it is jammed or hard to turn...replace that motor. Not that? There is likely a motor connector. Get a test light at the hardware store. Disconnect the motor and then probe the wires coming to the connector from the power side (with the power on again) to see if the tester glows. Yes...bad motor. No, find the bad connection. It is possible that this unit uses a multi switch...if that's the case, there will be three wires coming out of it...One is power in...the others go to the light and the fan. Then, the switch will be the culprit. Hope this helps.
Posted on Dec 09, 2007
Faber range hood fan stuck
Can you start the fan while holding the motor? If it runs fine while not in the hood, then likely the fan is rubbing against something that is not letting it get up to speed. If the motor does not run when removed from the hood, then there's something wrong electrically - a start capacitor, bad motor, etc. Try to verify the fan is not rubbing on something first.
Jan 21, 2014 | Faber Kitchen Ranges
Can you send me a link for instructions on how to install the hood?
http://faberonline.com/technicalspecs.html for instructions on all models, thanks
Jan 20, 2014 | Faber Cristal HC 598041 Kitchen Hood
Parts -- # 133.0073.597
i need the same part. where did you order it from? thanks.
Jan 19, 2014 | Euro-Pro Faber Axia Isola Plus Kitchen...
I've replaced both lights in my Faber (Classic) cooker hood but though the extractor fan works the lights dont and they're powered by the same source. The light switch is on and the flap close switch is...
Probably the transformer is blown on the hood, please write info@faberspa.com if no in North America or go to : http://faberonline.com/service.html
Jan 27, 2011 | Faber (272607) Kitchen Hood
I HAVE A FABER RANGE HOOD AND THE FAN IS NOT WORKING
sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
May 26, 2009 | Faber Diamante Wall Hood
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Fan Not Working
Dec 05, 2007 | Faber Cristal HC 598041 Kitchen Hood
Ballast for fluorescent lamp
instal a day light lamp insted a white light one, the ballast is set to an specific watage...good luck
Aug 12, 2006 | Faber Cristal HC 598041 Kitchen Hood
Faber Cristal HC 598041 Kitchen Hood Logo
48 people viewed this question
Top Faber Kitchen Ranges Experts
Steve
Carmen Mikulic
Bill Boyd
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
