Question about Rimage Amigo II (555501201) CD-R Burner
Unit will burn two or three discs and then stop to reboot
Our machine is quite old but it has been a work horse
  • 206 Answers
So now what is that u want to do? specify your problem in comments and rate this!!!
Posted on Jul 12, 2010
My hp Pavillion dv6 laptop can no longer use Constant Guard which Comcast supplies. Also Quattro Pro quit working midstream. How do I fix it?
More then likely running System Tuneup replaced critical files that Comcast Constant Guard and Quattro Pro uses... I recommend doing the following three steps but only if you have the Original or backup copies of the installation disc/media for both applications: 1) uninstalling the Comcast Constant Guard application 2) then do a normal shutdown and reboot once it has rebooted 3) install the Comcast Constant Guard once that's done and successfully do the same three steps but for the Quattro Pro application
Jan 02, 2015 | HP Pavilion Computers & Internet
My QD-DVD Microboard burner, only three of the bays will burn CD's the other two will not.
hey john, u must go to the website from Microboards
and there u must look for the latest firmware for your unit
when u found it than burn it on a cd or dvd
and than follow these instructions and u are set to go and the unit must work normal again
The Update Firmware feature is used to update the controller firmware.
1. To update the firmware: Place the firmware CD into the reader drive (top).
2. Press the ENT button
3. The display will show the current and update firmware
versions, as shown to the right:
4. Press the ENT button to complete the firmware update.
5. The duplicator will reboot automatically after installing the new firmware
Nov 25, 2013 | MicroBoards QD DVD 123 Burner
Lost the user password on my laptop toshiba 2100cds how do i change or recover
Without having to format the computer you will need the following to change the password.
  • A Blank CD
  • Another computer to burn a disc
  • Hiren Boot CD www.hirensbootcd.org/download
Then you need to...
  • Download hiren and unzip it
  • Burn the .iso file to disc (You need to select "Burn image to Disc" from your favorite CD burning program) You can get Nero Lite for free if you need one.
  • Make sure the laptop is set to boot from CD first in BIOS
  • Insert the burnt hiren disc into the laptop and reboot
  • From the menu select the "Active Password changer"
  • Follow the prompts and select your user and change the password to be blank
  • Now save and quit and reboot the computer
  • When you are back to the login screen you should be able to login with no password.
Comment if you need additional assistance.
Aug 08, 2011 | Computers & Internet
The heater stopped working granted it is old and has not been in the best environments however, I would like to see if it can be fixed. I hear something loose inside the heater
I think your heater is probably worn out. I bought one of their units twenty plus years ago and did not do maintaence on it as I should have. It was used a lot as my wife was staying home and besides taking care of our own two she babysat for three or four more. By the time it started giving me trouble I took the back screen off and cleaned lots of dirt and lint out and got another two years out of it. When it quit a small section of the ceramic disc broke off and it was cost prohibitive to buy repair parts.
This is a very good unit but now it's jist less expensive to buy a new radiant heater every 3-4 years. Sorry I know that's not much help. Thank you.
Jan 20, 2011 | Pelonis Disc Furnace Heater
Just stopped working. No lights, no clock. Starting brewing for a few seconds then quit working. About a year old.
Contact Cuisinart directly. They have a three year warranty on all of their appliances and they are the only ones in the country authorized to do service on their machines.
Nov 01, 2010 | Cuisinart DCC-1200 Coffee Maker
DVD burner will not burn or finalize
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Jun 15, 2009 | Lite On LVC-9016G DVD Recorder/VCR
Both Windows media player and DivX quit burning files, windows says everything worked but the disc is still empty, Divx will start burning but then freezes and stops responding
i think the disc is not recordable anymore or i guess it does not support video files cd+r disc is better for video recording
Nov 14, 2008 | Computers & Internet
I have a 4 year old Calypso Sears washer. With medium to large loads, and heavy loads, such as towels and blankets, it will wash the clothes, but stops and shows a code of CA or Cl when it goes to do the...
If you want a work horse, find your local Speed Queen dealer and buy a Top loading washer, Look for a model like an AWS76NW or AWS52NW. Basic Top loader, work horse.
Let me know if you have questions.
Aug 21, 2008 | Washing Machines
Burning smell followed by failure to freeze/chill Whirlpool sbs
Sounds like it was just the Compressor relay failing. Sometimes when they fail(and they all do)-- they fail shorted......not open(the compressor just wouldnt work) and they melt down. Sometimes it ruins the terminals on the compressor. But it is a relatively simple repair and a 3yr old unit should be worth the repair.
Jan 16, 2008 | Refrigerators
Rimage Amigo II (555501201) CD-R Burner Logo
Top Rimage Computers & Internet Experts
David Payne
David Payne
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
