Question about Dell Inspiron 1525 Laptop
My dell battery will not charge anymore. it says
My dell battery will not charge anymore. it says plugged in, not charging. bought a new battery; same thing so not battery.
  • 34 Answers
Charging circuit on motherboard or you can try a different A/C adapter. Start with the adapter first, they're pretty inexpensive $20-$35. If that doesn't fix it then a motherboard replacement is your solution unfortunately. Check with Dell on your warranty options.
Posted on Jul 12, 2010
My Dell Inspiron 3520 laptop is not charging, the charger/adapter is not working. I cannot fix it, bought new battery and adapter and they do not charge. What do I do?
Is the plug that you connect the adapter to still properly connected to the mo bo? If not, the adapter will not work nor will it properly charge the battery. Bet that if you charge that battery to another working laptop your new battery will take a charge.
Sep 04, 2017 | Dell Computers & Internet
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
My dell d600 is not charging what is the solution and it always flash red light when it is plug to power
That means either the battery is no longer good anymore or the laptop is unable to charge and/or recognize the battery. Try cleaning the contacts of both the battery and the laptop when everything is unplugged and powered off with alcohol and a q-tip. But usually if a laptop is not charging the battery then most likely you will need a new one
Apr 13, 2011 | Dell Latitude D600 Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
My dell axim does not charge a new battery- I tried 2 new ones.
check the charging unit or the plug on ure phone,it mite be loose and not charging
Sep 24, 2009 | Dell Axim X50 Pocket PC
Dell inspiron 8100 no ac power-power only with battery
You may have to run the battery/charger utility test.Look under control panel classic view.
Jul 14, 2009 | Computers & Internet
The battery does not charge anymore ,the bios setting says idle
remove battery and reseat.
Use VOM (Volt-Ohm Meter) and phsically check to make sure the power supply is putting out advertised voltage (typically 19-20 VDC)
Make sure power supply recepticle (the female part on the laptop itself) has not been broken or reamed out such that contact is not being made.
When you plug power supply in, does the charging light on the laptop come on?
Mar 07, 2009 | Dell Latitude D600 Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1525 Laptop Logo
158 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
