Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Canon 2200 eletrical surge now getting error code it says to turn power on and off. But that does nothing and it shows error code E000002-0000
  • sawn Jul 12, 2010
    That was great!! It worked perfectly. Thanks, and Thanks
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
Error code (E002) is also a fuser error code. Lets reset this code. Press "additional functions”. Then press the numbers 2and 8 at the same time, then press additional functions again. This will put you into service mode. The new menu you see will look weird as it will be blue and have several "boxes" on the menu with "COPIER" at the top of the list. Touch copier and it will highlight, then press "ok" at the lower right corner. This will summon a new menu which will have several tabs at the top. Of those tabs press "function". Now there will be many items listed in the main field of the screen. One of the items will be "CLEAR". Press it, it will highlight. One of the options will be "ERR". Press it, it will highlight. Press "ok" located at the lower right corner. Now, press reset until you get back to the main which will again display the error code. Now reach around the right side at the back, slightly below the halfway point and you will see/ feel the rocker switch that is truly the main power and shut it off. Wait 5 seconds and power it back up. It should work fine now.
Thank you for contacting Fixya and please accept the solution if it has helped you.
Posted on Jul 12, 2010
Have an error code of E602-0001. Please Help! The machine is a Canon imagerunner 2200.
This an error code for the failure of the Hard Disk Drive. You may be able to save the HDD by powering down the copier. While holding the 1 & 9 number keys at the same time power on the copier. This similar to a CHKDSK on a computer. Hold the two keys down until a rectangular box shows up on the display. If after lets say 20 seconds nothing appears then you will have to replace the HDD and reinstall system software. This may be better left to a qualified service tech. He will ahve to use special Canon software to complete this repair.
Jun 23, 2011 | Canon imageRUNNER 2200
Reset Error codes
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
I have a cuisenart dcc 2200 coffee maker. We had a power surge.
mcdevito75, Unit coild be burned out from power surge, Test at a known good electric outlet. If burned out replace your coffee maker.
Jun 22, 2010 | Cuisinart Brew Central® DCC-2200
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
IR2200
When I pluge my Canon IR 3300 is showing me to Turn OFF and ON the Switch in the right, if the problem did not solve, so please send solution on Email - rajkumarsingh_kushwah@yahoo.com
Apr 28, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Error Code E000001-0002
Did you press additional funcation? You have to in order to get in to service mode. Then go to copier, then funcation, then CLR/ Clear, then ERR, the hit the OK on the display, then turn the main power switch OFF then back ON. It should reset the code, if not you have a problem with the fixing unit.
Sep 02, 2008 | Canon imageRUNNER 2200
CANON IR 2220 POWER PROBLEM
Does it show error code? Also does it ever get out of the wait state? The "bar" at the bottom? Also, does it ever go in to the regular display sceen? If the display turns black, do you see a code or numbers like "602-001" ? Need some more info then just turns on and then off
Aug 25, 2008 | Canon imageRUNNER 2200
Solution to error e000001-0002
You have to go into service mode to clear the error code. Your problem with your copier is possibley that you had a power surge or a drop in voltage and it coded out or the fixing unit is shorting out.. You have to hit the right bottons.
Mar 20, 2008 | Canon imageRUNNER 2200
Computers & Internet Logo
42 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
