Question about Gateway 831GM PC Desktop
Won't boot I recently upgraded my computer with a new video card but when I set my computer back up it would turn on but not boot up. The fans would not rev up and no icons will appear. The computer is totally unresponsive to keyboard and mouse commands and it wouldn't work even when i removed the video card. Any advice would be most appreciated.
  • 5 more comments
  • trushinogul Apr 20, 2008
    Lights do come on so i think it's getting power. When it's turned off there's a green light on the back that lights up meaning that it's plugged in, and of course when i try to boot it up the blue light inside the power button lights up. However no fans spin at all.
    300
    and it was a pci card
    Correction: my fans do rev up but for only a second. Other than that all information is correct.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    It wasn't a PCI-E card?
    Are you sure you didn't hit any connections when you put it in or took it out?
    Do you have on board video?
    Were you replacing an internal video card?
    If not and you have on board video, did you disable the on board video before you turned on the pc with the new card in it?
    Sorry for all the questions, just trying to help the best I can.
  • Jeffrey Pemberton
    Was it an AGP card? How many watts is your power supply?
  • Jeffrey Pemberton
    Are you getting any power at all? Does the power supply fan spin?
  • 667 Answers
I would've suggested removing the memory chip had I known about it. Any hardware changes are the first things we ask but you didn't tell me that one. How about giving me a fixed ya rating for my hard work. It would be much appreciated. Thanks.
Posted on Apr 21, 2008
Thanks for you assistance guys. I neglected to mention that the new video card came with a new memory module that I installed soon after I installed the video card. Unfortunately, the memory module wasn't seated properly and created a short circuit. I removed the memory chip and now my computer works fine.
Posted on Apr 20, 2008
Updated Bios for Toshiba Satelite C55-A5286 and now computer keeps crashing
Sounds like it may be related to the installation of the new vid card. I'd take it back to the shop where I had it worked on and tell them the problems your experiencing and tell them they screwed it up and you want it fixed-pro bono!
Jul 11, 2017 | Toshiba SatelliteR C55-A5286 Laptop...
Cpu fan failed
bench test the fan
or could be just dust build up
Apr 07, 2017 | HP Pavilion 515n (DC471A#ABA) PC Desktop
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
My aspire x1300 won't turn on just the fan runs
This may be caused by more than one issue ..
If it makes any beeps ..and restarts in a loop ..it may be the ram memory ..and if you upgraded it recently you may need to check the compatibility ...specially the frequency ..If the board does not supports the frequency of the module ..this may be an issue..So either put back old one ..or try to identify which one is not working ...by inserting only one at the time and boot up ..
another cause may be a damaged video card ..and in this case will start ..and show nothing and usually beeps long and than nothing ..If you have a agp or pci card ..and you also have a on-board one ...just remove the video card from the slot ..and insert the cable in the on board plug ..and give it a try ..This way .., if it works , you will know it is the card to blame ..and change it ..
The 3rd possibility is the cpu ..went dead..If the fan is working ..but no beeps or other warnings ..it is usually the cpu ..cause other devices causes restart or beeping ..and the cpu failure is the only one quite ..If you check all others and seam to be ok ..than you must consider to replace the cpu ..
Jan 09, 2012 | Acer Computers & Internet
My hp a362n doesnt want to boot.
your problem is not clear it's not booting or not comming display ?
Jan 07, 2012 | HP Computers & Internet
My computer shuts down after a few minutes
2 possible issues come to mind: 1) the computer is getting hot (CPU, memory or video card), 2) the power supply can't keep up with the demand.
Try using a program that lets your track your computer's internal temperature. System Information for Windows, http://www.gtopala.com/ , is the one I use. Depending on the cause, you may need to increase the ventilation of your case (add fans - slot cooler by the video card, front, back or side panel.). If the CPU is getting hot, make sure that the CPU cooler is working and consider removing it and reapplying a new layer of thermal paste before reattaching the cooler.
If the problem is the power supply, check the specs on your devices (memory, CPU, video card) and the power supply load rating. You may need to upgrade the power supply.
I hope this helps.
(I am not a gamer but the default power supply that came with my computer didn't have enough power for the added memory and video card. I replaced that and added a back fan (spot available), a slot cooler, a drive bay fan and cut a hole to add a side panel fan.)
May 08, 2010 | Biostar P4M900-M4 Motherboard
After power on Fans are running but no Videosignal, no bios startup.
Could be 3 things Memory or CPU or Powersupply. are you getting any beeps if so how many, how long. try taking all the memory out and powering up see if it beeps if so try to put one stick of memory in at a time and see if it will boot. if you get no beeps with memory out check powersupply some PS's have a red switch on back for current input. switch back and fourth about 20 times uning a pen and set it to the right current for you location. put ram back in see if it will boot if not its trial and error of the PS and the CPU replacement and it still could be the RAM giving false readings. yea i know sounds like a ball of fun.
Feb 24, 2010 | Intel D915GAV Motherboard
Monitor wont work
You were not very clear with your question. If you mean you have disabled your onboard video, then installed the new video card and get nothing then the card is not compatible with your system OR you got a bad card. If you mean you simply installed the card, turn on your computer and get nothing until you move your monitor plug back to the original port (without turning off the computer) then you must disable your onboard video by going into your BIOS settings. Follow the instructions that came with your video card or your computer to do that. Usually you get in by pressing delete or F2 while the computer boots.
Jun 06, 2009 | Evga e-GeForce 7300GT 512MB Graphic Card
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
Trouble booting after cleaning
Try unplugging the dust on the cpu grooves under the cpu fan.
Hope it helps
Nov 22, 2007 | Abit A17 Guru Motherboard
Gateway 831GM PC Desktop Logo
108 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
