Question about MSR Family Tents
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
    New Friend:
  • 4 Answers
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
  • Lisa Manzanares
    Lisa Manzanares Aug 13, 2016
    Just what o was looking for! Thanks so much!!
ward_knutson
  • 64 Answers
SOURCE: need an instruction booklet for Wild Country Blaxland 64283 Tent
If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
http://www.coleman.com/coleman/images/pdf/2000000136.PDF
Posted on Dec 16, 2008
  • 272 Answers
SOURCE: Wenzel Monarch Tent instructions
Wenzel does. They e-mailed me one for a different model that I bought on eBay. They're website doesn't offer any help but they were very helpful when I called!
1-800-325-8368
Posted on Jun 03, 2009
  • 17 Answers
SOURCE: Instruction to put up a Coleman Rock Springs 4 Tent please?
Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
Lay it down, stretch it out and peg it. That will save you a ton of time.
Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
Good luck
Posted on Jun 09, 2009
SOURCE: Need instructions for a coleman salt lake tent
Are you still in need?
I have just bought one and could send you a photo of the instructions.
Posted on Jun 25, 2009
SOURCE: coleman salt lake tent 9 man no instructions please help?
the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
Posted on Oct 23, 2010
Instructions for assembling an American Camper Screen Tent #4662
Contact American Camper and request instructions for assembling screen tent #4662.
Jul 25, 2018 | Sport & Outdoor - Others
Instruction for 12 x12 screen tent
Amy, 12 x12 screen tent setup. Check the attached links,instruction and guides, you can also try Google search your make and model# instructions. Good luck. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://store.eurekatent.com/media/document/SCREENHSE09IM.pdf
Screen Tent Instructions eHow
http://www.shelterlogic.com/support/manuals
12 x12 screen tent instructions Google Search
Aug 27, 2016 | Sport & Outdoor - Others
Instuctions for Ozark tent
Stacy, Check the attached links tent setup ,instruction and guides, Good luck
Ozark trail 8 person instant tent
Assembly Instructions for Ozark Trail Tents
How to Assemble an Ozark Trail Tent
ozark 8 person instant tent Google Search
Jun 08, 2016 | Camping, Backpacking & Hiking
Can you help with assembling american tent
Need more info. Any model number or any numbers or description
May 19, 2014 | Grilling
Black hard plastic broke, its where the three poles goes in to hold the tent up. need to find this part so we can enjoy using the tent
Remington tents were a licensed product manufactured by American Camper. For more information concerning Remington tents please contact them at:
Avid Outdoors/American Camper
1-800-782-2843
Sep 02, 2013 | Camping, Backpacking & Hiking
I need the instructions for the All American Barbie camping tent (1991).
http://service.mattel.com/us/ and click on the instruction sheet tab and you should find what you need. Good luck
Aug 07, 2011 | Toys
The instructions I got are not exactly for the tent in the bag, so I need to find out the specific instructions for my tent rther than the generic instructions it came with.
Search on the internet for the manufacturer's name, and the tent model. Most have instruction sheets downloadable from their websites. If that doesn't work, and they can't help you by email, then try to find a scout troop or outdoors club in your area, who may be able to help you find instructions or even someone with a similar tent.
Apr 02, 2011 | Sport & Outdoor - Others
MSR Family Tents Logo
2,956 people viewed this question
Top MSR Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a MSR Sport and Outdoor - Other Expert? Answer questions, earn points and help others
