Question about Onkyo TX-SR606 Receiver
Dead - Onkyo TX-SR606 Receiver
    Guru:
  • 257 Answers
On the back panel of your receiver, there should be a fuse holder. Unscrew and check if the fuse needs replacing.
Posted on Jul 13, 2010
The dead series in order
Dead Wrong
Dead Silent
Dead List
Dead Lost
Dead & Buried
Dead Nasty
Calladine Bayliss
Aug 21, 2017 | Cars & Trucks
98.3hombre battery went dead after a jump it wont start
double posted, why?
JUMPS OK
AFTER JUMP WORKS AND DRIVING, AND STOP AND KEY OFF
IT WILL NOT CRANK.
did i guess right?
that means ,
check all fuses first. even the alt fuse (large)
1-battery bad? #1 top failure all cars.
2-Charge system bad. (is the charge/ batt warn lamp glowing when running car, bingo.????
3-or phantom drains. (if no crank just after stall then it not this) if drains while sleeping yes.
the tests are easy, a dirt cheap voltmeter
13.3v to 15v running is good charge system.
if 12v and falling not.
if the battery is bad, the charge system can shut down, so, the best practice is to try a know
good battery out of 2nd car, do you have battery to barrow, this is TOP CHOICE< not thinner wallet.
if the good battery fails then the charge system is failing (note I said system and not a part)
or the belt missing or slipping to the alternator.
btw the 4.3L PCM runs the alternator
PCM is engine brain.
btww, same true 2.2l engine.
the regulator is in the PCM.
so is the charge/bat lamp in cluster
on key on, lamp test
the jump start it , it runs
does the charge./batt.lamp go out.
id be all over that lamp, costs nothing to look.
Oct 09, 2016 | 1998 Isuzu Hombre
How can i get my factory radio to work...turns on for a few minutes then turns off on its own
i dont think the 94 cars had the anti-theft feature."asking for code"
its dead in all modes, ?
Am/FM , Cassette, or CD
when dead the dial is dead,station scans dead too.
or just audio dead. but seems to be ok
if totally dead, that is a loose or bad Radio fuse
or if not, bad radio. time to upgrade, no?
Mar 13, 2016 | Geo Cars & Trucks
TURN signals, LIGHT NOT ON!
all 4 corners dead.
hazards dead. all 4 corners.
cluster lamp dead, for signals. dead. and haz?
only these symptoms work
if too hard all that
check fuses?
get it fixed?
any thing else dead or dodgy.
do tell that first.
Jan 09, 2016 | Jeep Grand Cherokee Cars & Trucks
When stalled car will not start again for some time and battery seems dead. What is this?
that is because it is dead?
that key dead thing is called NO CRANK, not no start.
no car starts unless cranked, or push started or gravity started,
so its a NO Crank issue,
and the stalls, well if the battery drops below 10v the EFI system
stop working just like your lap top does, or CEL phone
and for same reasons.
most folks do a jumper cable crank next. like the AAA tow truck man does first, and for good reasons.
this proves what is wrong,
1: battery was dead (car cranks now)
2: starter dead. or key line dead, if not. cranking now.
my guess is its #1
if battery was dead, then it is
  • bad battery.
  • only discharged, so why not charge it?
  • or phantom drains, (over night parking battery dies)
  • or alternator is dead, (chargelight glowing? test alt.
Mar 03, 2015 | Suzuki Swift Cars & Trucks
INJECTORS ARE NOT WORKING
wow no year, are you kidding? and worse no car body. wow. x2.
what does not working mean, they dont squirt
or they lack 12vdc on one side and the NOID signals on other are dead.
all dead means. (no squirts)
1: blown fuse.
2: main relay dead.
3: the ECU wants them dead.
4: fuel pump dead or ECU wants it dead.
what does want mean.
want means. the ECU logic, halts injection for these reasons.
A: lost spark.
b: lost CMP or CKP sensors, which kills spark
c: cranking wide open throttle ,cancel injections for magic secret unflood mode.
so , why did you start (if you did) at injectors, they are last to work.
all the above most work for or the ECU cuts fuel.
the ecu cuts fuel to prevent CRASH and BURN, as seen on TV.
so you check spark and you got what?
good, ? one dead , all dead?
if spark is all dead, scan the PCM.
does it show, P0340/355 DTC errors, for dead cmp, or ckp>
that be first , top of list after fuse checks.
tell car , year, and all symptoms, ?car will not start and spark is ////???????????
Feb 12, 2014 | Toyota Cars & Trucks
I have laptop this is totly dead when i open this laptop how can posible
Dead AC adapter?
Dead battery?
Dead motherboard?
Dead CPU?
Take it to a qualified technician, for professional trouble-shooting.
May 14, 2010 | Dell XPS M1330 Laptop
Cordless phone went dead
leave batt out for a long period of time,then replace
Nov 30, 2009 | Panasonic KX-TG2431 Cordless Phone
Can't post
Probably a dead power-supply.
Maybe a dead motherboard.
Maybe a dead CPU.
Not likely to be dead video.
Less likely to be dead RAM.
Take it to a qualified technician for trouble-shooting.
Nov 14, 2009 | Compaq Presario 5000 PC Desktop
Onkyo TX-SR606 Receiver Logo
111 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
