How do you remove printhead & replace it? - Office Equipment & Supplies
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
When you will open up the cover it will automatically bring the printhead to the front and you could click it out.
Posted on Jul 12, 2010
Print cartridges would not move to center when opening lid so that ink could be replaced
There could be a paper jam in the printer head clearning system. If the head cleaning system is not completing the cleaning motion cycle the carriage will not move the catridge to the centre.
Dec 15, 2014 | HP Photosmart Premium C309A All-In-One...
Why won't my printer print black with all new cartridges?
Remove all inks, then the printhead & sit the printhead on a soft cloth soaked in warm water - let it sit for a few minutes then reinstall, close lid then make the machine ask for the inks once the inks have then been installed it should prime the machine. If this does not work try it again & if that fails then your printhead probably needs to be replaced.
Aug 12, 2014 | HP PHOTOSMART PLUS B209A All-In-One...
How to unclog a unused printer cartridge
For your Kodak printer, you can follow the same procedure used for the HP Photosmart and Officejet printers which have removable printheads...just perform a quick 2-minute hot water flush on it:
1. Remove both ink cartridges.
2. Remove printhead (depress grey tab and pull out).
3. While the PRINTHEAD is removed, perform a hot water flush on the PRINTHEAD assembly:
Flushing Procedure: http://inkjet411.com/?page_id=2412
a. Over a sink, run warm tap water directly into the ink ports for approximately 2 minutes - this will effectively saturate the foam ports and blow ink out/thru the nozzle plate bottom.
b. Using a lint-free towel, remove water from rear/bottom electrical contacts. Ensure printhead electrical contacts and exposed surfaces are fully dry.
c. Install the printhead into the printer. You may observe a "Replace Printhead message" so you will need to cycle printer power by turning printer off and then on to clear the error.
d. Install ink cartridges and retest printer. You should observe a New PRINTHEAD alert message followed by an approx. 4-minute preparation countdown prompt.
--- If you have reached this point of the troubleshooting and all the previous troubleshooting steps did not work, then the printhead is likely damaged or at end of life* and may need to be replaced.
For information on North American ink refill services (HP, Epson, Canon, Lexmark and Dell) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 07, 2013 | Kodak ESP7 PP All-In-One Printer
Black not printing clearly bits blurred or missingtried head cleaning many times still not much better. What else can I do? Can printhead be removed &cleaned?how do I go about this?
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 10, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Canon MP510 does not print black, has new print head & new black ink cartridge, deep clean does not help, colors are OK. Initially it was intermittent black print. Now, no black at all.
Mar 21, 2011 | Canon Office Equipment & Supplies
Xerox Phaser 8560 displays the following error message when connecting the equipment 07,009:42:155474 What is the solution to this problem because the site of xerox found no reference to this error I...
This is out of the service manual. Generally you can just remove the sides and home everything and it will work fine.
Harry
The 7,007.49, 7,008.41, 7009.42, and 7,010.43 errors indicate that the
Printhead was unable to tilt normally on its axis. Possible causes include:
■ The printer was powered off in the middle of a cleaning cycle and the
Wiper Blade has frozen to the Printhead.
■ A Drum Maintenance Camshaft lobe is broken and holding the Drum
Maintenance Kit’s oil roller against the Drum when it should be retracted
to its home position.
■ Process Drive not being aligned correctly.
■ A damaged Printhead Restraint.
■ Ink spilled in the Roll Block preventing proper Printhead motion.
■ Ink or other debris under the Printhead preventing proper motion.
■ The Wiper Assembly not being aligned correctly or ink spilled in the wiper
tracks.
■ The Head Tilt Gear not being homed correctly.
■ The X-Axis Motor nose cone not being installed correctly.
■ The ferrite torrid on the Printhead interface cable has slipped behind the
Printhead causing the Printhead to bind when it tilts backwards.
■ The black plastic shroud on the back of the Printhead is snapped off and
binding the Printhead when it tilts back.
Caution
After servicing the printer, manually set the following assemblies to their
home position before powering on the printer. See Section 6 for
instructions on setting these components to their home positions.
■ Printhead (tilted forward and disengaged from Printhead tilt gear)
■ Head Tilt Gear (disengaged from Process Drive train; arrows on left
frame point to each other)
■ Wiper Assembly (bottom of travel)
■ Process Drive (holes on Transfix Camshaft and Drum Maintenance
Camshaft line up with marks on frame, large gears within assembly
line up with holes in Process Drive housing)
Aug 17, 2010 | Xerox Phaser 8500/DN Printer
HP Z6100- Magenta ink density fade
there may be air bubble in ink tube assembly if u can do the priming then ok o/w call hp service provider to do this
Jul 28, 2010 | HP Designjet Z6100 InkJet Printer
Replace print heads. How?
REPLACING HP PRINTER, PRINTHEADS
Follow these steps to replace the printheads in your printer.
  1. Press the Power button (c00636182.gif ) to turn on the printer.
  2. Open the top cover.
  3. Press and hold the Resume button (c01219285.bmp ) until the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and back on and then try holding down the Resume button (c01219285.bmp ) again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  4. Lift the printhead latch. Figure 3: Lifting the printhead latchc01290070.gif
  5. Lift the handle of a printhead and use it to pull the printhead out of its slot. Figure 4: Removing the old printheadc01295543.gif
  6. Shake the new printhead at least six times while the printhead is still in its packaging. Figure 5: Shaking the new printheadc01134519.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps. Figure 6: Removing the protective capsc01134520.gif CAUTION: Do not shake the printheads after removing the orange protective caps.
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead until it snaps into place. Figure 7: Inserting the new printheadc01290071.gif
  9. Pull the printhead latch all the way forward, and then press down until the latch engages. Figure 8: Closing the printhead latchc01290072.gif
  10. Close the cover. Figure 9: Closing the coverc01290073.gif
  11. The printer should align the printheads automatically in a few minutes, printing an alignment page. If it does not, go to the next section to align manually.
Align the printheadsIf you installed the HP software, use the instructions in the left column below. If you installed a Plug and Play driver or other driver, use the instructions in the right column.
Mar 05, 2010 | HP Office Equipment & Supplies
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
QY6-0049-000
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
k24674
jasbo
jasbo
