Please remove the front panel and clean carefully the contacts of the panel, also repeat the same with your dash connection of the panel. it should be shining. If this wont resolve next afterr checking the voltage on the set along with the auxillary voltage without any fluctuation, check for a good ground connection. loop one to confirm. if the problem stays, open the set and tighten all cords.check on the motherboard for any loose solder connections particularily in the power side. tap the set during the prrocess of service with the power connected. Hope this helps you find the fault.Good day.
