Question about Microsoft Xbox Console
Org xbox turns on, everything fine, but a can't the controller to work so I can get pass the clock setting screen? the controller works, because it was tested on a different system.
    Problem Solver:
  • 5 Answers
Ur controler ports r probably bad so u nid 2 change em
Posted on Jul 21, 2010
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jan 24, 2011 | Microsoft Xbox 360 Console
Same kinda thing
that would be your graphic card replace it and your xbox will work like new
Jul 13, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Screen won't show up but this is diffrent
This happened to mine and it had to be sent back to be repaired (3rd time) as the graphics card had failed; it started with the display colours looking strange, then the picture went totally. If you can hear everything working (beeping/whooshing" as you go through the "blades", it sounds like you have the same problem. below is how to reset to the default display sttings just in case anything has gone wrong on this.
To reset the display settings of the Xbox 360 console to the default settings, follow these steps: (Copy and pasted from Microsoft support pages)
  1. Remove any discs from the disc tray.
  2. Turn the console off.
  3. Turn the console on.
    Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
  4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
If this doesn't work then try phoning XBOX Support on 0800 587 1102.
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
XBOX 360 CONTROLER PROBLEM
Go to settings and turn controller invert off. (y axis)
Feb 24, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
