FixYa.com
Tags:
Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE makes Squealing Noise when switching it...
posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 12, 2008
Not Rated (0)
Agent Don
Rank:Wiz Wiz
Rating: 82%, 99 votes
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Posted by ray_s51 on Apr 20, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
how to use air pump
how to use air pump attachment... Answer This...
Vacuums
wand
my extension wand wont slide... Answer This...
Rainbow Shampooer
Where do the two tubes go at... Answer This...
Rainbow E Series
Hello...I read your answer to... Answer This...
Rainbow Rainmate
I have a Rainbow Rainmate with... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
