Question about Nintendo DS Lite Console
My ds A buttons stuck
My a buttons stuck its perfectly up but it ALWAYS works it never stops well i did use action replay but still it never stops working how do i get it to work but not over work
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
IMPORTANT: it dont seem to be a grave problem but to solve this problem you need to dissasemble the intendo DS lite, so you must get some guidance like youtube videos on how to dissasemble the NDS Lite or other webpages with info on dissasembling the unit.
You need to carefully open the console to clean posible liquids and/or dirt on your buttons rubber pad under the plastic button piece.
Liquids and dirt may get stuck in the circuit board producing a false contact that only have to be when you push the button against the circuit board.
First take out the battery and charger to avoid short circuits. Clean the contacts and rubber pad with a dry paper towel or similar. Also can use a bit of alcohol 95% over the paper to get it humid and clean any grease.
Good Luck...
Posted on Apr 20, 2008
My ds
If you are experiencing errors with this you can reset it by following these directions...
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn't hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
Feb 27, 2011 | Datel Action Replay for Nintendo DS
My new action replay ds worked fine for about a month
did you try to clean the ds slot connector?? you should try to clean the action replay cartridge connector pins...Good luck!!!
Sep 09, 2009 | Datel Action Replay for Nintendo DS
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
Aug 03, 2009 | Datel Action Replay for Nintendo DS
Action Replay DS has stopped working altogether.
It must be completely broken. If you are desperate, you can always try putting a very small drop of liquid in it, the blowing like crazy.
Jul 05, 2009 | Datel Action Replay for Nintendo DS
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Jun 13, 2009 | Datel Action Replay for Nintendo DS
Why did my action replay erase every game and
Wilsonboys38, all you need to do is reset the system. I can't remember how to do this so check out www.codejunkies.com
Jun 10, 2009 | Datel Action Replay for Nintendo DS
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
May 13, 2009 | Datel Action Replay for Nintendo DS
Action Replay Ds Pokemon cheats not working
im sorry i cant help you with that but you should stop trying becuase action replay ds totally destroyed my friend's ds and i would hate for you to buy a whole new ds becuase action replay ds destroyed yours
Apr 15, 2009 | Nintendo DS Lite Console
My ACTION REPLAY WON'T WORK!!!!!
Everybody has the same problem!! ITS UR ACTOIN REPLAY!!RETURN IT!!!!!!!!!!!!!!!!!!!!!!
you have the wrong answer action replay back to its factory settings ( the way you bought it )
Mar 05, 2009 | Nintendo Action Replay DS for DS and NDS...
Action Replay for the DS won't Work at all
connect the usb to the pc.when you power up the ds lite with action replay in palce.press the select,start,A and B button at the same time.this will format your areplay.now update the action replay via internet and it will update all the games on your action replay.
Dec 17, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
272 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
