Question about Troy-Bilt Pony Garden Tiller
Replace Tecumseh engine with a Honda
I have an OLDER TB tiller. probably built in the 80's. I 'think' it is the smaller model, maybe the pony? I have not used it in about 15 yrs and the motor does not run anymore. What I KNOW about it: It has 8" wheels and a Tecumseh engine. Not sure of the hp.
I want to replace the engine with a Honda if possible, but I need some info in order to buy the right type. It 'appears' the shaft is 11/16 diameter, but I am not familiar with any engine having that size. Bigger than 5/8, but smaller than 3/4. What would it be? It does not appear to be tapered. The bolt pattern appears to be either 2 1/2 or 2 5/8". Does you records give any info on these specs?
5 Suggested Answers
Remag1234
  • 387 Answers
SOURCE: I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
Posted on May 17, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
  • 26 Answers
SOURCE: Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
Posted on Oct 08, 2010
SOURCE: Hello, I have an older Troy
Where can I get parts for my TH 1002 TB tiller? I
Posted on Feb 18, 2011
NEED A MANUALC FOR TROY BUILT PONY TILLER THE ONLY NUMBER.I CAN FIND IS 20512CT
You can get this manual directly from the troybilt.com website. A lot of manufacturers have their manuals available and just out of curiosity I checked there and in they do have tillers like the one pictured here. Enter pony tiller in the search box and you'll get a page of their different models. Click the one you have and it opens into another window showing the tiller, and beneath it is a bar with "overview" Specs" "Accessories" and "Parts & Manual" You can download the manual and - "yippee!!" - it's even free.
May 18, 2014 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Aug 03, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Not getting spark
I would check that I didn't have a key sheared off in the flywheel, that the start/stop switch isn't faulty, and that there is no missing or weak flywheel magnet. Hope this helped and best wishes.
Jul 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I need a new motor for horse model, serial no. 360331. which models fit this troy built.
Just about any engine with a 3/4" horizontal shaft that is internally threaded on the end and has the four bolt mounting pattern around the shaft will work. I have gone to Harbor Freight and purchased their 6.5 H.P. engine that is a Honda clone and it will work fine and only costs $100-150 dollars. The only difference is that it uses a metric bolt to hold the pulley on the shaft,the four mounting bolts are metric and you have to disconnect the low oil shutoff or the engine will die when you are tilling deep. It is a good low cost option for the Horse tillers.
Frank
Jun 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need free repair manual down load on Troy Bilt Junior 500 30 82
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Free manuals for Troybilt here
May 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
142 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
