Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
How do you replace the spark plug wire on a ry30060b?
  • 718 Answers
It is not as simple as just changing the wire you will need to change the wire and the coil it comes as one piece. What is the reason for this question, if it is because of broken wire then you have to replace, if you are not getting spark to plug then replace. If in good condition and getting spark do not replace.
Posted on Jul 12, 2010
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Tip
How to Test Spark Plugs in Audi A6 car?
1) Test the spark plug ignition. For that disconnect the spark plug wire from the spark plug.
2) Then touch the spark plug wire close to a metal surface of the car. Then spin the key in ignition switch. If you will see a spark or hear a crackling noise. This means the wire to the spark plug has voltage in it.
3) If there is no spark when you crack the engine it means that a spark plug wire is dead.
4) Check out all the battery cable, ignition wires and coil wires are hooked up properly to their points.
5) If any of the battery cable, ignition wires and coil wires is loose then this can also relate to no spark.
6) But if all the battery cable, ignition wires and coil wires are properly connected then its time to replace the spark plugs.
7) Before replacing clean the old spark plugs connections and recheck.
8) Many a time’s cleaning or moving the spark plug connections makes it work.
9) If nothing is getting the spark plug to spark, then it needs replacement.
This will help. Thanks.
on Mar 15, 2010 | Audi A6 Cars & Trucks
Tip
How to Test Spark Plugs in car?
The procedure is as follows:--
1)Test the spark plug ignition. For that disconnect the spark plug wire from the spark plug.
2)Then touch the spark plug wire close to a metal surface of the car. Then spin the key in ignition switch. If you will see a spark or hear a crackling noise. This means the wire to the spark plug has voltage in it.
3)If there is no spark when you crack the engine it means that a spark plug wire is dead.
4)Check out all the battery cable, ignition wires and coil wires are hooked up properly to their points.
5)If any of the battery cable, ignition wires and coil wires is loose then this can also relate to no spark.
6)But if all the battery cable, ignition wires and coil wires are properly connected then its time to replace the spark plugs.
7)Before replacing clean the old spark plugs connections and recheck.
8)Many a time’s cleaning or moving the spark plug connections makes it work.
9)If nothing is getting the spark plug to spark, then it needs replacement.
on Mar 15, 2010 | Audi A4 Cars & Trucks
How do i remove a stuck spark plug wire on a 2003 pontiac grand prix
You will have to replace the wire. Pull old one off remove spark plug pry the metal end of the wire off the spark plug. Replace spark plug install new wire. there is anti stick for spark plug wiring I would use if I was you
Aug 07, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
I have a broken spark plug wire. Can these be replaced?
Steve:
Yes, the spark plug wire can be replaced, but you have to buy the ignition coil as the spark plug wire is hard wired into the ignition coil.
If the metal spark plug connector has disconnected from the spark plug wire, the connector can be replaced, but if the spark plug wire has been cut you'll need to replace the ignition coil.
Nov 29, 2013 | Homelite 200 mph 400 CFM Gas Blower...
Tip
How to Test Spark Plugs in Audi car?
on Mar 15, 2010 | Audi A3 Cars & Trucks
Cylender number 1 misfire,
Do a complete tune up.. Spark plugs, wires, distributor cap, and rotor button... If it has coil packs that sit on top of the spark plugs.. Replace the spark plugs and cylinder number one coil
Feb 15, 2011 | 1998 Nissan 200SX
Describe your how fix my pontiac 2000 montana Problem changing spark plugs
Inspection
Inspect for the correct routing of the spark plug wires. Improper routing may cause cross-firing. Inspect each wire for any signs of cranks or splits in the wire. Inspect each plug wire boot for tearing, piercing, arcing, carbon tracking or a corroded terminal.
If there is any corrosion, carbon tracking or arcing indicated on a plug wire boot or terminal, both the plug wire and component it was connected to should be replaced.
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the left side spark plug wires from the spark plugs.
  3. Remove the left side plug wires from the retaining clips.
  4. Rotate the engine for access as follows:
    1. Set the parking brake.
    2. Shift the transaxle into neutral.
    3. Remove the engine mount strut bolts. Swing the engine mount struts aside.
    4. Install the Engine Tilt Strap J-41131.
    5. Pull on the engine in order to rotate the engine forward.
    6. Tighten the strap.
  5. Remove the right side spark plug wires from the spark plugs.
  6. Remove the plug wires from the retaining clip.
  7. Remove the spark wires from the ignition coils.
  8. Remove the plug wire assembly from the engine.
    NOTE If you are replacing the spark plug wires, the spark plug wire conduit and retaining clips should be transferred to the replacement wires.
To install:
  1. Install the right side plug wires to the ignition coils and then the spark plugs.
  2. Install the spark plug wires to the retaining clip.
  3. Rotate the engine back to the original position.
  4. Install the left side spark plug wires to the ignition coils and then to the spark plugs.
  5. Install the spark plug wires to the retaining clips.
3.9L Engine
  2. Remove the intake manifold cover.
  3. Remove the left side spark plug wires as follows:
    1. Disconnect the left side spark plug wires from the spark plugs.
    2. Disconnect the left side spark plug wires from the ignition coil.
    3. Remove the left side spark plug wire clips from the intake manifold and heater inlet and outlet pipe.
    4. Remove the left side spark plug wire assembly.
  4. If removing the right side spark plug wires, the engine must be rotated for access as follows:
  5. After rotating the engine, remove the right side spark plug wires as follows:
    1. Disconnect the right side spark plug wires from the spark plugs and ignition coil.
  6. Remove the right side spark plug wire clip from the ignition coil bracket.
  7. Remove the right side spark plug wire assembly.
To install:
  1. Install the spark plug wire assembly.
  2. Install the right side spark plug wire clip at the ignition coil bracket.
  3. Connect the plug wires to the ignition coil and spark plugs.
  4. If the engine was rotated for access, return the engine to the original position.
  5. The remainder of the installation is the reverse order of removal.
Feb 05, 2011 | 2000 Pontiac Montana
NEW PLUGS AND WIRES
The correct arrangement?
I always remove one plug wire, replace that spark plug, and then replace that one spark plug wire. This way I never cross which plug wire to which position.
Oct 29, 2009 | 1999 Volkswagen Jetta
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
145 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
