Question about Cepia One Touch Pistol Motorized Power Sprayer
I hace a Cepia On-touch one gallon motorized tank sprayer. it is brand new, I just opened it and it does not spray. batteries are good, seals are good, so what can it be? Cepia sold that division and they can not tell me who to contact!
  • 718 Answers
Take it back where you bought it and get a new one why try to figure out something like this if it is brand new, be serious you must be an engineer or a med student? HA HA good luck PAL
Posted on Jul 12, 2010
Need an o ring
Check with the guys that fit tyres..They normally have a variety of these O-Rings.. Not sure what they use it for but it worked for m
May 18, 2012 | Cepia 1 - Touch 1/2 Gallon Rose & Garden...
My ChapinSpray N Go sprayer won't build air pressure in the tank when I pump the sprayer
Sounds like a faulty seal to me. Submerge the container in water and pump, bubbles will rise from the seal. Easy to fix, I had a look and you can pick up a seal replacement kit for this model at Amazon.com for under $12.00. You should also find them at any reperitable hardware store. Hope this helps :)
Feb 03, 2011 | Chapin 2 Gallon Spray N Go Pump Free...
The sprayer makes noise like it wants to spray but does not spray
water is getting to it but not passing through, i have never seen one of these but deal with sprayers all day long sooooo open it up there is a valve somewhere that is stuck clean all components and lubricate with petroleum jelly put back together if it doesnt work u need a new one
Jan 25, 2011 | Cepia One Touch Pistol Motorized Power...
I have a Cepia 1-Touch but it will not spray? I have use new batteries however I still get the same results? Can you help?
sometimes after a lull in use, you need to remove and reinsert the same batteries, or cchek to be sure not rusted or ccontqat is good by wetting nodes. Must use all same brand batteries.
Sep 10, 2010 | Cepia 1 - Touch 1/2 Gallon Rose & Garden...
GUN WILL NOT PUMP (CEPIA 1 TOUCH ELECTRIC SPRAYER
Regular O-rings off the shelf at any hardware should fit this thing. They come in those boxes of all sizes, the only ones you won't find are the little tiny ones. About 1/16 inch. Your gun shouldn't have any that size. You can buy a new pistol for about $8.
May 05, 2010 | Cepia One Touch Pistol Motorized Power...
Clogged and can't get the weed killer to pass through the power wand
EASY FIX!
Hold the sprayer lower than the tank and run it until it sprays. You're done. They seem to lose prime, it usually happens to me when I run it completely out and/or first use (almost year round for us). Mine works fine every time I do this.
If that doesn't work, check the filter on the end of the hose in the tank, blow compressed air through it - NOT BY MOUTH!! Also check for any leaks/pinholes/kinks in the hose - they will **** air instead of solution!
I've had mine for 3 seasons in Phoenix and love it! I've n never had any of the other problems I listed personally. Handle the liquids like you handle gas for your lawn mower, etc:
1) Don't let any dirt to get in the solution.
2) Wash the system before storage ESPECIALLY AT END OF SEASON by spraying clean water through It for a couple of minutes or so and rinsing the tank. STORE INSIDE FOR THE WINTER if it freezes, it may trash it. Leaving anything stronger than Roundup (TM) in it for more than a week or so may eventually damage the plastics and/or seize the pump too.
Apr 30, 2009 | Cepia "" Hands Free Power Sprayer
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Cepia One Touch Pistol Motorized Power Sprayer Logo
268 people viewed this question
Top Cepia Garden Experts
Dennis Key
Dennis Key
john h
Are you a Cepia Garden Expert? Answer questions, earn points and help others
