Question about Hotpoint RGB508 Gas Kitchen Range
Pilot light in oven whistles
Pilot light whisles. hotpoint #rgb508
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I c
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Can't seem to access Hotpoint Stove Pilot Light? Also is there a second pilot light for the oven?
For the last 10 years or more there are no pilot lights on gas ranges. Modern ranges have an electronic igniter on the burners and a different type on the oven.
Cant light oveen pilot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Aug 07, 2010 | Hotpoint RGB508 Gas Kitchen Range
When I set the oven to 400 degrees for example, after 20 minutes the burner and the pilot turned off completely and whatever I'm cooking won’t get cooked.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Hotpoint RGB508 Gas Kitchen Range
I can't find the pilot light on my Hotpoint gas stove. Where is it?
Depends which pilot light you're talking about. There are two for the hobs and (I assume) one for the oven. I can't find the one for the oven, hence why I'm on here looking through forums (a..?)
Cheers.
Mar 04, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas range model RGB508 pilot is lit but oven burner don
are we talking about the oven.if so and the ignitor lite's up,and look's as strong as it was,than you my have a BAD SAFTY VALVE.
Nov 26, 2009 | Ovens
Where is the pilot in my hotpoint oven?
As far as I know, there is no pilot light in any domestic oven up to 25 years old and probably even in the older models.
Nov 26, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas oven Hotpoint RGA 720 I can't light the oven pilot
There is likely some kind of gas line blockage or valve problem. This is not a do-it-yourself fix. Call a repair person.
Oct 15, 2009 | General Electric Hotpoint® RGA720PKWH Gas...
Hotpoint RGB508 Gas Kitchen Range Logo
82 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
