Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Hard to read temp setting on electronic touch pad
    President:
  • 1,891 Answers
Replace the clock the display is behind the touch pad .. mm
Posted on Jul 16, 2010
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 | GE Ovens
RF214LXTS 0 I have a whirlpool stove, have power on both incoming legs. the top works fine, but the bake and broil elements in the oven dont work. the saftey fuse on the back seems to ohm out good as...
The way power typically is supplied to the bake/broil elements is that directly off the terminal block 120volts ac is supplied directly to the elements at all times and when the touch pad is pushed a relay on the clock/eoc (electronic oven control) will close and supply 120vac so the element has 240vac to heat. you should be able to see the wire coming directly off the terminal block where the cord from the house wireing connects to,going directly to the elements and as stated above theother 120 vac from the relay to the elements (their is 2 relays,one for bake and one for broil)
As far as testing the oven sensor(temp probe) at room temp the ohms reading should be 1060-1100 ohms and as the tempature rise the ohms rise so to test it verify is 1060-1100 at room temp then heating it usinga blow dryer,match or cigarette lighter and the ohms should rise as it gets hotter and drop when its cooling
Good luck,i hope this helps and if it does help please give me 4 thumbs up
Gene
Jul 27, 2011 | Whirlpool Ovens
F1 in temp window plus beeping
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz16K0oPAWb
Nov 25, 2010 | Jenn-Air Ovens
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
F0 fault code
Hi ,
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
May 29, 2009 | Jenn-Air Ovens
F7 Code stuck on
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
May 12, 2009 | Maytag MEW6630C Stainless Steel Electric...
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
43 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
