Question about Kicker Solo-Baric L5 Car Subwoofer
Kicker L5 not working
It looks like the coil on the inside is ripped a little, I wanted to know was there any way that I can fix it. Also what would be the approximate cost to repair it if it can be fixed.
  • Kicker Master
  • 17,130 Answers
If the coil on the inside is looking ripped, it must be rubbing against the inner walls of the magnet. check of failure of continuity of the coil. if open and rubbing then you will need to replace the coil. I shall guide you through this job. carefully disconnect the coil lines to the frame, then using a good sharp tool remove the side suspension and the inner spider that suspends the coil. now you can remove the whole assmebly. if the coil is damaged then slowly cut out the coil, get a replacement of the same diameter from the spare parts shop. if not available you will need to have some experience to wind the coil in the same diameter with the same SWG. Once you get the coil fix it carrefully to the speaker diaphragm centrally, then centrally place into the speaker mountings with the coil just in the gap, not rubbing against the magnets. now you can glue out the spider and suspensions. there you are. Good luck .
Posted on Jul 13, 2010
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have 2 kicker L5 subs and they are blown the
Yes you replace both voice coils. Get parts from another speaker but has to be equle in quality.
Apr 19, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Ho do i take it apart
Check the wires in the back sometimes the wire may brake and if you know anyone that can solder very well they should be able to fix that easy.
Oct 18, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How do you wire l5 to 2 ohm
Hello lholt07,
If the L5 has 4 ohm voice coils, you simply wire both voice coils in parallel, both marked and unmarked positive terminals together and to the amp and likewise with the negative terminals. If the L5 has 2 ohm voice coils, it cannot be wired to 2 ohms.
Hope this helps.
Sep 19, 2009 | Kicker Solo-Baric L5 Car Subwoofer
IS IT POSSIBLE TO REPLACE A BLACKENED COIL ON A 15 INCH L5? THE AUDIO REPAIR GUY TOLD ME HE DIDN'T KNOW IF YOU COULD REPLACE THE COIL, SAID I PLAYED IT TOO LOUD.
no - the coil cannot be replaced on any kicker speakers except the SOLO X
It is a proprietary part. Even kicker will not repair a speaker that is out of warranty.
You have a doorstop now (or passive radiator).
i am an authorized kicker dealer and get MANY questions about L5 and L7s.
I have (4) 15" L7s in my garage - hoping - someday - they will release spare cone assemblies. But for right now - they are displays only.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 15, 2009 | Kicker Solo-Baric L5 Car Subwoofer
12" kicker l5
Series is +amp to +1, -1 to +2 , -2 to -amp . This way you have wired the two voice coils into one higher impedance voice coil.
Dec 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
12" l5 no sound
Hi
maybe your voice coil is open circuit! or you have burn voice coil! thats why your unit is not functioning!
Thanks!!!!
Apr 30, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Snaped speaker wires
Solder the two ends together or sell the speaker to me wakesslide12@aol.com
Oct 25, 2007 | Kicker Solo-Baric L5 Car Subwoofer
Kicker Solo-Baric L5 Car Subwoofer Logo
250 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
