Question about Lexmark X2580 Wireless All-in-One InkJet Printer
The new ink cartridge smears near the last sentence of the page. is there a way to clean it? This printer is a Lexmark X2580.
    Genius:
  • 1,087 Answers
Perhaps the Lexmark X2580 User's Guide will be able to help you. Just click on this link: http://bit.ly/a9VQt7. Scroll to Achieving better print quality, Page 37, for instructions on how to clean the printhead. Hope this helps.
Posted on Jul 12, 2010
Lexmark x2580 all in one printer
The Lexmark X2580 only uses the #2 & #3 cartridges. You can purchase it online at http://bit.ly/TkGrwB.
Aug 22, 2012 | Lexmark X2580 Color Inkject All-in-One 600...
Blue and yellow not printing
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
Should the problem continue, please contact Lexmark Technical Support Center to have your genuine cartridge replaced. They might ask for your receipt so have them ready. If you're not using genuine supplies, please replace your cartridges with original supplies.
Dec 27, 2011 | Lexmark X2670 All-In-One Printer
My Lexmark X6170 is smearing all images that are about a third of the way down the paper. Everything else is printing fine.
Try to clean the cartridge nozzles using the printer control panel.
  1. Load paper.
  2. Press Copy.
  3. Press Options until Maintenance appears on the display.
  4. Press the right arrow until Clean Cartridges appears on the display.
  5. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  6. Print your document again to verify that your print quality has improved.
Also, check your ink levels. Make sure your ink levels are substantial for printing.
May 18, 2011 | Lexmark X6170 All-In-One InkJet Printer
Will not print.
First try to clean the gold contact points inside the printer, where the cartridge identification chip comes into the contact with the printer. this is located inside the cartrige slots. If that doesnt work check that the correct colours are being inserted into the correct slots. If you are using un-original cartridges or cartridges that have been refilled they may be incompatible or have been damaged through refilling, you must purchase original lexmark cartridges.
Jul 15, 2010 | Lexmark X2580 Wireless All-in-One InkJet...
Error code 1203
Hello
It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge. I have the same problem which I think lexmark has to overlook in production.
Solution:
I use the Kleenex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of Kleenex on those holder contact panel.
Best regards
Oct 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
The printed pages have pink blotches on the right hand side of the paper and horizontal pink blotches down the page
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
Sep 17, 2009 | Lexmark Office Equipment & Supplies
Lexmark X2580 won't print after cartridge refill
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Lexmark cartridge... see if that solves the problem. Which it very well could work off the Lexmark brand again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
The Man Inside the Machine
May 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Ink
They are series models. They are just the same I believe.
Jul 26, 2008 | Lexmark X2500 All-In-One Printer
Printer Problem
you should go to your LEXMARK solutions center either on your desktop or in your start menue and open the maintenance program and run the alignment. select the best arrows and enter them where indicated. this should help clear up your problem with a new cartridge
Oct 08, 2007 | Lexmark Z645 InkJet Photo Printer
Lexmark X2580 Wireless All-in-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
