Can't send fax through magicjack - Office Equipment & Supplies
  • 223 Answers
It is very unlikely that you will be able to send faxes through VOIP. All faxes have an analog fax card, and magick jack is a digital service, if you purchase a digital to analog filter that may work but is not supported by your fax machine. you can also attempt to change the fax speed to medium and error correction mode to off.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
I have a Cannon MX860 all in one machine. I have tried sending a fax multiple times with different baud rates down to 7200. The other machine answers and the two begin negotiation and the speaker goes...
its not the printer but magicjack. I have the mx860 its great but magicjack stopped supporting fax after an update came out. mine used to work great, but then just stopped after no change on my end
Jun 18, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
I have a Lexmark ProProspect 205 and when i try to fax using MagicJack I keep getting remote errors right after the dialing and sending process. What can I do? I only bought MagicJack in order to utilize...
The printer will have it's optimum performance when plugged in to an analog signal. MagicJack has digital signal which is very unreliable. Not really recommended to be used as a fax line since transmission signal through it is poor. Remote Fax Error comes up when you have a poor quality of transmission. Also, check if you have assigned it with the correct fax number and a fax name. But I strongly advise you to use analog transmission signal tel line for faxing. Hope I can assist you more on this. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 21, 2010 | Lexmark X2350 All-In-One InkJet Printer
How can i use my fax with magic jack.using lexmark X2350
This is the answer that I got from the FAQ page.
SOMETIMES.
We do not officially support using faxing with magicJack.
Please try the following steps to use magicJack with your fax (contact your fax manufacturer for details):
  1. Turn off error correction on your fax machine or program
  2. Set the fax machine or program to use the slowest speed available
  3. Increase the speed, checking at each speed that faxes work
It seems that it depends upon the faxing unit that you use.
Mar 31, 2010 | Lexmark X2350 All-In-One InkJet Printer
Fax on g85 w/magicjack (voip)
No, ALL fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line or Magic Jack.
Nov 05, 2009 | Office Equipment & Supplies
I have an intellifax 775 (brother) that i just hooked up to magicjack. How do i make it send and receive faxes?
ALL fax machines are ANALOG devices, MagicJack is DIGITAL. Your fax machine will perform unreliably, if at all.
Jun 25, 2009 | Office Equipment & Supplies
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
I have magicjack phone service how to get and send fax
fax machines are ANALOG, Magicjack is DIGITAL. Your fax machine won't work reliably.
Jan 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
295 people viewed this question
k24674
Marvin
Marvin
