My whirlpool top loader cold water doesnt come in for rinse.
  • busy74 Jul 12, 2010
    Thanks a lot. Very helpful.
    President:
  • 1,554 Answers
This is usually an issue with a faulty water inlet valve. Verify this by interchanging the wiring of the valve solenoids. That is, connecting the wires of one valve solenoid to the other and vice-versa then restart the rinse function. The wires for the cold water valve solenoid are now connected to the known good hot water valve solenoid. Hot water should fill in when the machine calls for cold water which will confirm that the cold water valve is indeed not activating, especially when cold water does not fill in when the machine calls for hot water now that the solenoid wiring are interchanged.
Check the wiring connection of the cold water valve solenoid to the timer if hot water does not flow in when the machine calls for cold water but cold water flows in when the machine calls for hot water now that the solenoid wiring are interchanged. Make sure the wires are intact and the connections are snug fit. Replace the timer if the above troubleshooting procedures does find any problem with the valves and the wiring.
Please indicate the exact model number of the machine for the specific procedure on how to access the water inlet valve assembly. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 12, 2010
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate Care II top loader washing - rinse issues
New concentrated powdered detergent takes very warm water to break it down. As for most dark clothes use cold water. I have one of these top loaders and for my cold wash colored clothes I use a liquid detergent and have no problem.
May 06, 2010 | Whirlpool LSQ8000 Top Load Washer
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
Cold water rinse just trickles on my whirlpool heavy duty top loader
There is a screen inside the inlet valve that is most likely plugged. Turn off the water and remove the cold hose from the washer inlet valve. You can see the screen just inside the valve. If the particles are a light brown color, it may be water softener resin, requiring a softener repair. Foreign matter can also include sand or other particulates in the water supply.
Apr 25, 2009 | Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
The water doesnt go into the area where the soap is
it only go's into that compartment on the very last rinse,you have,3 compartments .(1,hot )(2 cold)(3 softener)
Sep 03, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
