Question about LG HBM 730 Bluetooth Headset Wireless Headset
Can't get charged
My LG HBM 730 bluetooth headset can't get charged. The LED indicator didn't show solid red light when it's connected with charger and after 2 hrs, it gives only 5 min talk with the headset!! What's the problem? Thanks.
Wei
  • Maffers May 02, 2008
    I have the same problem
  • Anonymous Sep 03, 2008
    CAN'T FIND THE HANDBOOK. WHAT DO I LOOK FOR TO SEE IF THE EARPIECE IS CHARGED ALL THE WAY?
Same problem
Posted on Jul 31, 2008
My HBS 730 LG Stereo Bluetooth head set doesn't seem to come on. It seems not to charge up according to its indicator light.
the rechargeable battery has died and usually not serviceable by the consumer .check with a phone store .
Dec 08, 2015 | LG HBM 730 Bluetooth Headset Wireless...
How do i charge my lg bluetooth headset with AC charger. I cannot find an adapter insert on the headset.
HI. You will need to remove the concealment cover on the charging port before you can connect the charger. The cover is on the opposite side of the volume button. It will have the initials "PWR" on the cover. Pull that off to expose the charging port.
Aug 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
HBM 730 Bluetooth Headset Wireless Headset: Headset was given to me a while ago and I have a n...
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Hope it works for you
Hope it works for you.
Cheers! Carlos
May 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
I just bought a LG HBM 210 bluetooth and it doesn't appear to be charging... no LED light, and I can't pair it with my cell phone.
You need to work out if the charger or the device is faulty. The faulty item will have to be replaced by the shop where you bought it.
Apr 25, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
My LG HBM-210 doesn't seem to charge as the charging LED indicator just flickers on and back off.
Hi decross 903 Did you find a solution....I have the same problem? I plug it in to charge, the light comes on temporarily and then off. I have no idea if it is charging or not.
Dec 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
I cannot get it to connect. My Palm Centro recognizes it, but says that is unable to connect even though it has done so in the past.
Try disconnecting the bluetooth device then turn the bluetooth off then hold the power button untill the bluetooth shows a solid red light then try connecting the bluetooth between your palm and the bluetooth device hope this helps
Oct 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
How do you put the LG earpiece in pairing mode???
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
Oct 11, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
534 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
