Question about Kitchen Ranges
LG dehumidifier, LHD65EBL does not draw water and there should be buckets, in this heat wave we are having here. I checked the troubleshooting guide in manual, still not working.
  • 2,272 Answers
A dehumidifier uses fans to draw in moist air. The air is first passed through a filter to remove dust and particles, then to a cold evaporator where the moisture condenses into water. The water is then collected in a container for disposal. Check and clean filter. The filter and coils are clogged with dirt. Unplug the dehumidifier, then remove and empty the water-holding tank.
Remove the front and back grills. You'll have to either use a putty knife and pry between the top of the grill and the cabinet body to release the catches, or use a screwdriver to unscrew the fasteners.Clean the filter with a mixture of warm, soapy water and bleach. The bleach will kill any mold or mildew, so it won't be blown around the room when the machine is running.Clean the evaporator coils, using a vacuum with brush attachment. Remove any stubborn dirt with a scrub brush and a household spray cleaner, such as Formula 409. Scrub lightly so you don't bend the fins covering the coils.
  • Clean the fan blade and the other parts inside the cabinet, using the vacuum and crevice attachment.
  • Reassemble the dehumidifier, reinstall the water-holding tank and plug in the unit.
    Then check out.
    Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Posted on Jul 12, 2010
    I have a brand new LD651EBL. Picked it up this morning. Just plugged it in. Keep getting the CH 24 code. The bucket is all the way in. Is there a fix or do I need to return it?
    There may be some packing material left in the bucket or tape that is holding the float valve in place. In which case, the float valve may be in the UP position, which tells the unit, that the bucket is full.
    Check the top of the bucket for the float valve and make sure it's in the DOWN position. Reinstall the bucket 'squarely" in the bucket holder and making contact with the bucket safety removal switch on the rear wall of the bucket holder.
    If this continues to happen, consult the Troubleshooting Guide in the Owner's Manual.
    Hope this helps and thanks for choosing FixYa.
    Sep 11, 2011 | LG LHD65EBL Dehumidifier
    The De-humidifier thinks the bucket is full constantly
    This occurs when either the float valve in the top of the water collection bucket is stuck in the UP position or the bucket was not installed properly, making contact with the bucket safety removal switch on the rear wall of the bucket holder.
    Checking an correcting those 2 issue should solve the problem. Be sure to turn the unit OFF & unplug it before attempting corrective issues.
    Hope this helps you & thanks for choosing FixYa.
    Sep 09, 2011 | LG LHD65EBL Dehumidifier
    Does not kick in to run
    There are many reasons why a dehumidifier willnot work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
    Dehumidifier is running but no water is in bucket
    heatman101
    Aug 09, 2011 | LG LHD65EBL Dehumidifier
    Our dehumidifer runs and runs and there is no water in the receiving bucket. The settings are at 55%. Any suggestions? It's about 4 years old.
    heatman101
    Jul 10, 2011 | LG LHD65EBL Dehumidifier
    The unit runs, but dose not capture any water and sounds a little different while running.
    There are many reasons why a dehumidifier will not work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
    heatman101
    Jan 25, 2011 | LG LHD65EBL Dehumidifier
    Ran for 1 day and produced no water?
    No, it should produce water almost immediately in the bucket. Check that the air filter is clean and also the coils.
    Check the Lg.com website and look up your model # and manual for information on how to perform the service yourself.
    Good luck on this repair.
    Jan 08, 2011 | LG LHD65EBL Dehumidifier
    Dehumidifier will not come on it has power to it
    heatman101
    Dec 26, 2010 | LG LHD65EBL Dehumidifier
    No power
    heatman101
    Jun 27, 2010 | LG LHD65EBL Dehumidifier
    LG dehumidifier
    I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
    Sep 12, 2008 | LG LHD65EBL Dehumidifier
    Kitchen Ranges Logo
    181 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
