Question about Dell Latitude X1 Notebook
Dell X1 Won't turn on
Using a new power adapter, the X1 will not power up. The power adapter is good. No lights on the power button.
  • 206 Answers
SOURCE: My Dell laptop is powered using the ac adapter
Most probably is that your MB is fried. The battery does not serves as the power supply, it is also a regulator for the electricity. A small amplitude in electricity and the MB is dead without batt
Posted on Nov 19, 2009
  • 3940 Answers
SOURCE: Overnight, the laptop will not power up. With
Here is some information you can use to determine the failure:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
The LED indications of the LOCK Light LEDs at power on may give a more exact failure determination.
Posted on Dec 21, 2009
SOURCE: dell c640 laptop when not power on when using ac
Yes, you should replace you battery, go http://www.feevoo.com , you can find many cheap laptop battery, laptop accessories there.
Posted on Jun 25, 2010
  • 308 Answers
SOURCE: my dell vostro 2510 won't
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Posted on Jun 18, 2011
SOURCE: My battery will not charge on my dell studio 1749 laptop. I ordered (from Dell) a new battery and a new adapter plug in. Still won't charge - the light blinks amber several time and then once wh
Great story, but I feel your pain. There are so many times people think that just because they bought it new it works. Not true at all.
Posted on Apr 23, 2012
Testimonial: "Thank you so much for your comments. They did help me tremendously."
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Mini dell 910, no power
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-dell-inspiron-mini-910-30w-ac-adapter-19v.html
Nov 21, 2012 | Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My Dell Inspiron Mini won't power up. When I push the "on" button, the light indicator flashes and goes off immediately.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 21, 2011 | Dell Inspiron Mini 10 Notebook
Hi,my notebook is not turning on .Charging is good .When i press switch button charging process is stopping to 1-2 seconds then continues .Maybe problems in motherboard?Product Details for ASUS F5RL-X1...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 16, 2010 | ASUS F5RL-X1 Notebook
Have a dell inspiron 1300 new battery was off about 2 weeks,plugged back in get slow blinking green light after all night wont come on when i push power button ???
Sep 12, 2010 | Dell Inspiron 1300 Notebook
Dell 1735 won't recognize new battery
try this:
remove battery
unplug power adapter from the laptop
hold power button down for ten seconds
this will drain the laptop power completely.
place battery back in and plug power adapter back in.
Now turn your laptop back on.
let it start normally
if you using Windows XP go to start button then control panel then power options and in the power meter tab see the computer sees your battery. check to see if battery light is on.
if not then buy your battery from.
May 29, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 1525 won't turn on
Try to take out the battery and just use the adapter to power it on,
If your done with that then try just using the battery to turn it on, if it still won't give a single light.
If you can borrow an ac adapter for that laptop try it ,
If it still doesn't work. You'll need to replace the motherboard. Just make sure the ac adapter your gonna use is working good.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Dell Latitude X1 Notebook Logo
3,420 people viewed this question
Alun Cox
