Question about Maytag Dishwashers
IS THEIR A DOOR ADJUSTMENT ON MY MAYTAG DISHWASHER MODEL #MDB5000AWB,IT WILL NOT WORK UNLESS YOU HOLD PRESSURE AGAINST THE DOOR
  • 4 Answers
SOURCE: maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Posted on Dec 20, 2007
rylee_smith
  • 8619 Answers
SOURCE: dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Posted on Feb 10, 2009
  • 1632 Answers
SOURCE: how do i adjust door switch on a maytag dishwasher
With a philips screwdriver turn the adjusting screww inside locking lever mechanisim, The latch at the top frame has adjustment screws too.
Vitally
Posted on May 14, 2009
  • 45 Answers
SOURCE: Door lach/handle plastic pins have broken off and
handle was redesigned with a metal rod through the attachment points to prevent breaking. the handle and latch comes as a complete assembly (you don't have to put it together).
Posted on Jan 10, 2010
  • 89 Answers
SOURCE: GE Nautilus dishwasher won't continue through
Hi, In reading about your dw problem, you are in need of a complete door switch assembly. You will need the full model number, and then find your nearest ge supply house to purchase the part. Hope this helps.
Posted on Jan 20, 2011
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
The Diswashers Maytag Quiet Plus II only works when we push against the door
It sounds like the door switch or sensor needs to be adjusted or replaced.
Nov 22, 2012 | Dishwashers
The dishwasher only runs when pressure is applied to front door. As soon as pressure is released, washer stops running
The door switch/latch is out of adjustment or faulty.
Go to RepairClinic.com and enter your full model # to see/order a replacement latch/switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 07, 2010 | Maytag Dishwashers
Dishwasher door leak
Hi
Thanks
Rylee
Feb 10, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Oct 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
363 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
