Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Water is green and i have a saltwater system - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • mark Gianotto Jul 12, 2010
    It would help if you put a little effort into what is going on with your pool other than it is green There are many factors why a pool goes green. 99.9% of the time it is due to inproper maintainence. What are the chemicals running at? What is the ppm of your salt How many hours a day are you running the generator? Are you using an algaecide? How about a stabilizer? I will wait to see if I hear back from you. A little elbow grease and I can get you to clear water Also would like to know what specific filter/pump you are using with the salt generator
    Sergeant:
    Champion:
  • 333 Answers
It's not makeing chlorine. You need to shock the pool and balance with chemicals.Your salt system needs to be cleaned or it's at the end of it's life
Posted on Jul 13, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
I own a saltwater system for my above the ground pool i am having trouble with the water turning green can you use other chemicals with this salt water system.if not wat can i do to solve this problem
Is the water turning green because of metal or because of growth? Is your salt water system making chlorine? If you are not making chlorine ... well that may be why you are green., On the other hand, if you have metal in the water and you ARE making chlorine, that is why you are green.
Please have your water tested for metal and if present, use the sequestering agent recommended by your professional pool supplier, to remove the metal.
A problem with the salt water system is the chlorine you make from the salt is not protected by cyanuric acid AKA stabilizer. I recommend you get your chlorine up to about 20 ppm (shock mode) using the kind of chlorine recommended (is compatable with the chlorine you are making) by your pool supply professional. Add enough cyanuric acid to achieve at least 60 ppm.
Let me know what you are doing ...
Thank you for your interest in FixYa.com
Jul 04, 2011 | Intex Automatic Salt Water System for ...
We recently purchased the intex saltwater system for our above ground pool. We read all the instructions and followed them however our water is still cloudy and a light shade of green. what can we do
You need a sequestering agent to remove the metal from your water ... let the chlorine go to nothing ... put in some 'metal out' or similar according to the instructions on the container ... then start again with the chlorine.
Chlorine and copper and/or iron = green water
Thanks for your interest in FixYa.com
Jun 25, 2010 | Intex Automatic Salt Water System for ...
My intex saltwater system green light then low salt light
You need to add salt to the water. How much depends on what size pool you have. Your owner's manual will tell you exactly how much to add when the low salt light comes on. On my Intex I would need to add 35 lbs.
May 30, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
356 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
