Question about GE GSL25JFPBS Side by Side Refrigerator
Evaporator fan not working
The evaporator fan started sounding like it was having trouble working then it eventually stopped. My initial thought is that the motor is bad, but since it is a $100 motor I thought I would ask if something else could cause this before buying a new one. The company I bought it from left no schematics, so I cant tra own the circuit.
    President:
  • 1,430 Answers
If the motor is getting power and not running you will need to replace it. This is a fairly common failure in these models. We have the part in stock for under $45 your part # is AP3875639
enter the part# or your model # at www.appliancehelponline.com
Posted on Jul 12, 2010
2005 Whirlpool Refrigerator GS5SHAXNL cycling on and off and fan has gotten louder. Is this normal?
When the water solenoid valve leaks by initially, the water overflows into the freezer evaporator and I have seen an ice stalagmite up to 2 feet high form near the evaporator fan. The ice is probably inpinging on the evaporator fan blades. If not corrected, the fan motor will burn out and will need to be replaced. Take you model number to searspartsdirect.com and get an new water solenoid valve and install it.
Sep 28, 2014 | Refrigerators
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
My fridge upper unit isnt working, there is no air circulating, i could hear the compressor working and it seems the lower unit is fine. it started by making a constant ticking sound and then a day later,...
You will need to look into the possible chance that your evaporator Fan motor has stopped, been damaged or the freezer is not defrosting properly. To allow it to continue running can damage the compressor. Click Here=> MFD2560HES Evaporator Components then 12002744 Evaporator Fan Motor and again the 67002493 Defrost Heater I have all the instructions and hands on if you would like my assistance I will be here to assist and repair you Maytag That ticking noise could have been your fan blade finally reaching the frost until the fan stopped. Let me know Here or or here on Fixya, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MFD2560HES Bottom Freezer French...
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
Evaporator fan works sometimes
by the sound of it , i would get a new evap fan,
as the power to the fan is switching on - thats why
you can flick it and get it running, the power is there.
it is a common problem with evap fans.
Dec 12, 2009 | GE GSS22JF Side by Side Refrigerator
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Frig section not cooling and at time appears to stop but freezer is ok
There is one compressor, condenser and evaporator in all refrigerators. The part that makes the cold inside the unit is the evaporator. It's in the freezer, behind a barrier on the back wall. It's a "coil" with many small fins. There is a fan that blows air over the evaporator which makes the air cold. This air comes from the freezer and stays in the freezer. The cold food section (the refrigerator) has a control that opens a hole for air to pass from the freezer to the fridge. This being said...you can rule out the "temperature control" for the fridge.
The sound you hear could be the compressor relay, the evaporator fan or maybe something else. It could be bad, it could be not too bad. (Like a fan blade a bit unbalanced with dust)
OK,,, back to the evaporator. There is a little heater next to the coil that turns on every 8 hours or so to defrost the coil. That's called the "defrost cycle". Makes sense, no? If the defrost timer (common problem) or defrost control board (common problem) go bad, your evaporator coil freezes up, and that's not good for anything in your refrigerator. But it can often keep the freezer section cold. You can easily disassemble the evaporator cover in the back of the freezer and take a look. If it looks like a block of ice, you probably have a defrost issue. An even, thin coat of frost is OK, but lots of ice is a no no.
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Groaning noise on GE side by side refrigerator
Hello Michael,
Thanks for your question, I hope I can help some. My answer is long winded but full of good info.
The noise could be as the GE guy said refrigerant (gas) noise. If it is refrigerant noise it happens as the liquid refrigerant comes out of the tiny capillary tube and enters the evaporator (cooling) coil in the freezer. Along with the liquid coming through the capillary tube there often are gas pockets. The flow of the liquid and gas pockets into the evaporator coil cause strange sounds. If the noise you are hearing is this refrigerant noise, you should only hear the noise while the compressor is running and then only for a short time (1 to 2 minutes) after the compressor shuts off.
If the noise continues after that I do not think it is a refrigerant noise.
There are times when the compressor will not be running but the fan in the freezer will be running on this model. This is normal and working properly but if the noise is present when the freezer fan is running and the noise stops when the freezer fan stops, the likely cause will be the main board located in a square panel on the rear of the refrigerator above the compressor compartment. I know that sounds crazy but the main board can cause the freezer fan motor to make some really strange noises. Eventually the board will probably fail.
One other test would be for you to listen for the compressor to turn off, then if the noise is present after the compressor turns off, you would next unplug the refrigerator from the receptacle. If the noise continues with the refrigerator unplugged it must be refrigerant noise. If it stops, I am betting on a bad main board.
I tried to locate for you information on a material that Whirlpool and Frigidaire as well as some others use as a noise deaden-er that they wrap around where the capillary tube enters the evaporator. I was not successful in locating anything. I am sorry I could not find it.
supertechks
Please don't forget to rate me
Jan 25, 2008 | Jenn-Air JFC2089HE French Door...
GE GSL25JFPBS Side by Side Refrigerator Logo
167 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
