Question about Compaq FP 7317 17" LCD Monitor
THE SCREEN DOES NOT SHOW ANY LIGHT OR IMAGES AND LETTERS OR NUMBERS
  • 76 Answers
Does it turn on? Check the power cord and monitor connections for power, monitor and computer.
Posted on Jul 12, 2010
How can I make the screen smaller when I want to.?
adjust your screen resolution. Higher numbers mean more dots per inch, and that means smaller images on screen.
Sep 19, 2014 | Computers & Internet
Vizio tv remote only types numbers not letters
Look on screen keyboard. There are keys to switch from uppercase, lowercase, numbers and special characters.
Mar 26, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
Some keys show numbers instead of lettes
You have the numbers lock on, all you need to do is press the Num Lk key down and the little icon light 1 should turn off and now all the letters will show letters only.
Have a good day.
Feb 09, 2012 | Sony VAIO VGN-N320E Notebook
I have a Sony Vaio (VGN-CR220E) that had it's backlight gone out. I've shined a flash light on the the screen and can still see my desktop. Also, before it went out, every time I started up my laptop the...
It could be your baclight that provides the power to the lamp in your screen, it can be the lamp as well, or could be an electrical fault with your motherboard, wrong voltage output to the inverter / faulty cable between the mbo and the inverter board. If it is the screen you can easly get one of ebay, there is a model number on the back, starting usualy with two letters and three numbers (those are in fact your screen dimensions) and then sometimes other letters/numbers + leters and numbers in brackets, eg. LTN154XB-L01 or LP156WH2 (TL) (C1). Accordingly you can ebay or google your laptop model number and type inverter or read the part number of the inverter (small ractgular board fitted below the screen). Not sure how to help if that is any other fault.
Feb 08, 2011 | Sony VGN-CR220E/L Notebook
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
LCD screen is on, not in hibernating mode but does not show any letters, derections, description
I think you have a lose connection caused by rotation of the flip up lcd screen. My MP520 does the same, but the characters display half way down when closing. I have not got round to opening it up to get to the guubings yet.
Apr 15, 2009 | Office Equipment & Supplies
Don't have user manual Get one?
Check to see if Num Lock is turned on. Depending on your computer, it may light up the key with a green light, or a green light may be lit near the part of the computer where the screen is connected to the computer.
Jan 15, 2009 | IBM ThinkPad T30 2366 Notebook
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Display is so light that I can barely read it, I've replaced the batteries and no change
Have you attempted darkening the display on the calculator through the function keys? Push "2nd" and then push "up" a few times. After resetting the calculator, this setting will always revert to a lower, unreadable setting. I'm sure TI knows about this, but they probably arent too inclined to fix it.
Jun 04, 2007 | Texas Instruments TI-83 Plus Calculator
Compaq FP 7317 17" LCD Monitor Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
