When I turn on my Acer Aspire 5534, the blue power light comes on, and I can hear the fan turn on for a second but then the fan stops and the screen stays black while the blue power light stays on. I try to turn off the computer by holding down the power button and the blue power light still stays on.
  • 1,606 Answers
If you never see any sceen display then you have a motherboard or cpu problem. If you do see a display even a bit then it would probably be a ram issue.
If you had noticed it running hot or warmer for a while it may have been a clogged or dirty cooling system and the cpu overheating. It can also be a ram problem which is the first thing I would check to rule it out. You also should sniff it top and botto and see if you can smell burnt or hot electronic. Other parts can be weak and be stressed and the extra heat of summer can cause them to go.
The blue light just indicates the power section of the board is fine. If the cpu isn;t running or locked up it will ignore the switch. Pull the plug and remove the battery to turn it off.
Unfortunetly the repair cost for either a cpu or mainboard are going to be a bit of $. If its ram based (not as sure on that) it just means popping in a new module and it should fire up.
I think the best advice I can give you from your symptoms is take it to a local tech or computer shop so theycan examine it hands on. Get an estimate which should be free. If it is under warrenty you should call Acer and they would fix it under warrenty. If it isn;t under warrenty then you need to be a bit cautious on repairs. If it is a cpu then a new cpu can be $100 and up, a new Motherboard is $150 and (waaay) up plus labour and shipping and taxes. Thats why you only want an estimate as you want to make sure as it may come to a fair portion of the cost of a new laptop.
I wish I could give you a good fix but with what you have described it would take having the laptop in hand to properlly assess the problem. And with a laptop because of the integrated way they are built the symptoms can be the same or appear to be for both a cheap and expensive problem.
Posted on Jul 12, 2010
  • lisagrant92 Jul 12, 2010
    Ok. I can send it to Acer because I have a warranty with them. But the reason I'm so worried about it is because I needed it for this week. If I buy a new Acer computer, not necessarily the same model, can I put the hard drive that was in my old computer in the new computer?
  • 4,737 Answers
Please remove the battery, unplug the power adapter's cable, leave it for few minutes, you also need to check the hard disk and the ram whether they are fitted correctly or not. If possible, remove the hard disk and boot up the system,(only using the battery or only with the power adapter) and try to get into the Bios settings, if it's possible, the problem is with the hard disk itself or with it's connector. Clean the interfaces on the connectors and reinstall it. Also remove the Ram and clean them, if possible please use another ram or in case you have multiple rams, remove one of them or leave only one to check the changes.
Let me know after you are done with all these,
good luck.
Thanks for using FixYa.
  • 1 more comment
    I removed the hard drive and tried to boot up the computer using either just the battery or just the power adapter, and the computer still did not boot up. But since the hard drive did not effect the condition of the computer, does that mean that the hard drive is not the problem? Also, where is the ram located? We do not have an extra ram.
    I found the location of the ram, and I had two discs so I removed one of them and kept one of them in, and the same thing happened to the computer.
  • Lebanon Raingam
    Lebanon Raingam Jul 12, 2010
    Good to hear that.. well then remove both the ram and see if you can see any changes or not. You'll also hear beep sounds if there's no problem with the motherboard. Install the ram one after another, also switch the slot. It's also possible the one of the ram is bad, so you need to find out.
    If In case you don't hear any sound, the culprit will be the Motherboard.
    Do let me know after you are done.
I have an acer aspire 5534 and I uninstalled mcafee it instructed me to restart and I do but then when my computer powers back on I get a blue screen with an error msg saying windows shut down...
u could try and use F8 when turnning it on by holding it down till writing comes up then look for lastknow configuration use the arrow key to highlight it then press enter
Nov 07, 2010 | Acer Aspire 55345410 Notebook
Acer 5534 seems to be working but the screen is not going on. it'
Change CMOS Battery and Remount RAM.. Then try to work..
May 31, 2010 | Acer Aspire 5315 Notebook
We have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Aug 23, 2009 | Acer Aspire M1640 Refurbished Intel...
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
ACER ASPIRE 3690-2940
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
