Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
Swingline 8786X, Power Ease, Desk model, manual. Has a quick load button at the back that will pop out the clip when you are ready to load. I cannot get the clip back into the stapler. It is about 1 cm short of closing completely. I have tried to remove some staples and load a smaller amount of staples, I have tried to close it with no staples, nothing is working. I cannot open the stapler either to see if there is anything jammed or another button. Any thoughts?
5 Suggested Answers
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
I have 8 boxes of 1/4" staples, 1000 staples per box, and I haven't an 800 or 900 staple gun, so I'd like either an 800 or 900 Swingline staple gun or for someone to buy my staples.
Posted on Jan 31, 2009
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
  • 132 Answers
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
Posted on Jun 27, 2009
How do I load staples in model 520e
Hello, Go to this website for a manual or call cust. support on this website. Swingline Manuals Swingline
Oct 23, 2014 | Swingline 520E Electronic Stapler Black
How to load a swingline optima 40 desk stapler
pull the top away from the center section this should open the unit
Aug 09, 2012 | Swingline Office Equipment & Supplies
How to open a stapler
Botton or tab on the bottom or by the hinge
Mar 01, 2012 | Swingline 87860 PowerEase ? Full Strip...
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
How do I open the swingline optima model # 8784x to reload staples?
I couldn't open my Swingline Optima model 8784x either. Their website wasn't helpful except they mention you can change staples "with the push of a button." Button, I thought. What button? In the picture, there's a black button at the back end of the stapler. Mine is missing! The button, if it were there, would press down on a metal tab, releasing the staple slide which pops out the front. Insert staples, push it closed, you're done! I used a letter opener to push down the metal tab.
Jun 27, 2011 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Need help to reassemble Swingline Optima desk stapler
You must have purchased the Swingline Stapler that is actually a Paper Weight. Do you have the 747 model, the one the airplane of named after?
Sometime the imbeded PC fails, preventing the robotic controls to release the staple or to reassemble automatically.
Please return for a complete replacement and a free trip to Disey Lane just pay for transportation, tickets, lodging, food, shipping, packaging, and handling. Have a nice day and thanks for flying with us.
Sep 15, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
2,298 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Van Allen II
Van Allen II
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
