Question about LG LMV1630 Convection/Microwave Oven
Wife ran for 14 min w/out anything in it changed fuse no luck
My wife ran the oven instead of the timer with out anything in the oven. just changed fuse with no luck. is it dead?
    Problem Solver:
  • 9 Answers
You need to change the cavity thermostat. The unit got too hot and blew the cavity thermostat. If this is a vent-a-hood model, it will be up under the vent housing at the top (must drop microwave to change) and if built-in, it will be on the left side under the outer cover. Just remove the screws from the back and sides and right along the edge along the bottom sides. Will have 2 wires going to it from each side. Just replace thermostat and reattach molex plugs. Then retest. Should be fine after that.
Posted on Jul 30, 2010
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Help used micro as timer but pushed start instead now wont work
Unplug it and try it again, may just need power on off reset
Aug 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Killed the microwave by running it empty for 30 minutes.
YES THERE IS AN INTERNAL FUSE OR DIODE YOU CAN CHANGE, BUT YOU SHOULD BE CAREFUL AN LET A PRO DO IT, YOU JUST DON'T WANT TO GET ZZZAPPPP WITH THE CAPACITOR THAT STORAGES HIGH VOLTAGE INSIDE TO PROVIDE THE MICRO WITH POWER, IT MAY SEEM LIKE A LIL UNIT BUT IT CAN HURT YOU IF YOU DONT DE-ACTIVATE IT RIGHT, NOT SURE IF THE DIODE WOULD BRING IT BACK BUT CHECK WITH A SERVICE MAN, BEFORE DOING ANYTHING I WOULD!
May 28, 2009 | Samsung SMH7178STD Microwave Oven
Oven won't function after 5 minutes of cook time with nothing in
It's posible that since it was running empty, the magnetron overheated and a thermal cutout or thermostat located on the magnetron opened.
Magnetrons may be protected by a thermostat, which will reset when it cools, or a thermal fuse, which is a one-time use device. It is also possible that in some cases, a thermostat will fail when opened.
In the worst case the magnetron may be damaged due to running empty.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 07, 2009 | LG LMV1630 Convection/Microwave Oven
No Power
Yes there is a fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Feb 22, 2008 | GE JVM3670 Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
LG LMV1630 Convection/Microwave Oven Logo
131 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
